Xavier nx
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0
questions
I connected a USB camera typed logi HD 1080P to Xavier NX board, and run the command the following command to capture and display the video:
gst-launch-1.0 v4l2src device=/dev/video0 ! capsfilter caps="image/jpeg" ! nvjpegdec DeepStream=1 ! nvvideoconvert ! nvegltransform ! nveglglessink window-width=800 window-height=600
but I got the following error :
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:01.052352557 16938 0x55a4d21630 WARN nvvideoconvert gstnvvideoconvert.c:3098:gst_nvvideoconvert_transform:<nvvideoconvert0> error: Memory Compatibility Error:Input surface gpu-id doesnt match with configured gpu-id for element, please allocate input using unified memory, or use same gpu-ids OR, if same gpu-ids are used ensure appropriate Cuda memories are used
0:00:01.052487149 16938 0x55a4d21630 WARN nvvideoconvert gstnvvideoconvert.c:3098:gst_nvvideoconvert_transform:<nvvideoconvert0> error: surface-gpu-id=159,nvvideoconvert0-gpu-id=0
0:00:01.052881357 16938 0x55a4d21630 ERROR nvvideoconvert gstnvvideoconvert.c:3484:gst_nvvideoconvert_transform: buffer transform failed
ERROR: from element /GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0: Memory Compatibility Error:Input surface gpu-id doesnt match with configured gpu-id for element, please allocate input using unified memory, or use same gpu-ids OR, if same gpu-ids are used ensure appropriate Cuda memories are used
Additional debug info:
/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvvideoconvert/gstnvvideoconvert.c(3098): gst_nvvideoconvert_transform (): /GstPipeline:pipeline0/Gstnvvideoconvert:nvvideoconvert0:
Execution ended after 0:00:00.852023537
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
If I change the plugin nvjpegdec to jpegdec and delete the attribute named DeepStream, it is OK. But the CPU load is over 50%.
