Problem: Using any driver above 510.x, my display (over hdmi) reports incorrect timings and does not output. I’ve checked xrandr outputs and the timings are all the same on 510 and 520. I’ve tried many kernel version (currently on 5.15.0-53) and versions of 515 and 520, and all exhibit the same problem.
Monitor: Dell SE2717H
OS: Linux Mint 21 x86_64
Kernel: 5.15.0-53-lowlatency
DE: Cinnamon
WM: Mutter
CPU: AMD Ryzen 7 3700X (16) @ 3.600G
GPU: NVIDIA GeForce RTX 3060 Ti
$ xrandr --verbose
Screen 0: minimum 8 x 8, current 3520 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (0x1bd) normal (normal left inverted right x axis y axis) 598mm x 336mm
Identifier: 0x1bc
Timestamp: 18383
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CscMatrix: 65536 0 0 0 0 65536 0 0 0 0 65536 0
EDID:
00ffffffffffff0010aca1d053395031
2d1c0103803c2278eacd25a3574b9f27
0d5054a54b00714f8180a9c0d1c00101
010101010101023a801871382d40582c
450056502100001e000000ff004b3956
3856384238315039530a000000fc0053
4532373137482f48580a2020000000fd
00384c1e5311000a2020202020200182
020320b14c9005040302071601141f12
1365030c001000681a00000101304be6
2a4480a0703827403020350056502100
001a011d8018711c1620582c25005650
2100009e011d007251d01e206e285500
56502100001e8c0ad08a20e02d10103e
96005650210000180000000000000000
00000000000000000000000000000028
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 3
_ConnectorLocation: 3
non-desktop: 0
supported: 0, 1
1920x1080 (0x1bd) 148.500MHz +HSync +VSync *current +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1be) 174.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 83.89KHz
v: height 1080 start 1083 end 1088 total 1119 clock 74.97Hz
1920x1080 (0x1bf) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c0) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1600x900 (0x1c1) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x1c2) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c3) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x720 (0x1c4) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1c5) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1c6) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1152x864 (0x1c7) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x1c8) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1c9) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1ca) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1cb) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1cc) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1cd) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1ce) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1cf) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d0) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
DP-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d1
Timestamp: 18383
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: DisplayPort
ConnectorNumber: 2
_ConnectorLocation: 2
non-desktop: 0
supported: 0, 1
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d2
Timestamp: 18383
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 2
non-desktop: 0
supported: 0, 1
DP-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d3
Timestamp: 18383
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 1
_ConnectorLocation: 1
non-desktop: 0
supported: 0, 1
DP-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d4
Timestamp: 18383
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 1
non-desktop: 0
supported: 0, 1
DP-4 connected 1600x900+1920+0 (0x1d6) normal (normal left inverted right x axis y axis) 443mm x 249mm
Identifier: 0x1d5
Timestamp: 18383
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0 2 3
filter:
0 1
EDID:
00ffffffffffff0059250020502d3101
25170104a52b1b7822c905a3574b9c25
125054254b00950081808bc001010101
0101010101017c2e401062841c3060a8
1300bbf91000001e9a29a0d051842230
50983600bbf91000001c000000fd0038
4b1e510e000a202020202020000000fc
00412f47323035360a0a0a0a0a0a000a
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 0
_ConnectorLocation: 0
non-desktop: 0
supported: 0, 1
1600x900 (0x1d6) 119.000MHz +HSync +VSync *current +preferred
h: width 1600 start 1696 end 1864 total 2128 skew 0 clock 55.92KHz
v: height 900 start 901 end 904 total 928 clock 60.26Hz
1440x900 (0x1d7) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1360x765 (0x1d8) 84.500MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.58KHz
v: height 765 start 768 end 773 total 795 clock 59.85Hz
DP-5 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1d9
Timestamp: 18383
Subpixel: unknown
Clones:
CRTCs: 1 0 2 3
filter:
0 1
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 0
non-desktop: 0
supported: 0, 1
