I am experiencing persistent CQE errors on server equipped with Mellanox ConnectX. The errors are logged in the system kernel log and I would like to request your assistance in decoding the specific “vendor syndrome” codes to understand the root cause.
Here are the relevant error entries from our logs:
Nov 26 06:18:17 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: Error cqe on cqn 0x981, ci 0x1d16, qn 0xc00885, opcode 0xe, syndrome 0x2, vendor syndrome 0x11
Nov 26 06:18:17 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: Error cqe on cqn 0x98b, ci 0x1cf2, qn 0xc00887, opcode 0xe, syndrome 0x2, vendor syndrome 0x11
Nov 26 06:18:17 cmp221 kernel: mlx5_core 0000:01:00.0 eth-net0: Error cqe on cqn 0x103, ci 0x3f4, qn 0x175, opcode 0xd, syndrome 0x2, vendor syndrome 0x68
Nov 26 06:18:17 cmp221 kernel: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Nov 26 06:18:17 cmp221 kernel: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Nov 26 06:18:17 cmp221 kernel: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Nov 26 06:18:17 cmp221 kernel: 00000030: 00 00 00 00 12 00 68 02 0a 00 01 75 9d c8 49 d2
Nov 26 06:18:17 cmp221 kernel: WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x1dc8, len: 64
Nov 26 06:18:17 cmp221 kernel: 00000000: 00 9d c8 0a 00 01 75 04 00 00 00 08 00 00 00 00
Nov 26 06:18:17 cmp221 kernel: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 01 80
Nov 26 06:18:17 cmp221 kernel: 00000020: c2 00 00 02 e8 eb d3 13 48 7a 88 09 01 01 01 14
Nov 26 06:18:30 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: TX timeout detected
Nov 26 06:18:30 cmp221 kernel: mlx5_core 0000:01:00.0 eth-net0: TX timeout detected
Nov 26 06:18:30 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: TX timeout on queue: 0, SQ: 0x185, CQ: 0x853, SQ Cons: 0x4d63 SQ Prod: 0x4d78, usecs since last trans: 15222000
Nov 26 06:18:30 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: EQ 0x7: Cons = 0x6bd0f, irqn = 0x132
Nov 26 06:18:35 cmp221 ovs-vswitchd[6736]: ovs|00001|ovs_rcu(urcu4)|WARN|blocked 1000 ms waiting for main to quiesce
Nov 26 06:18:42 cmp221 audit: PROCTITLE proctitle=2F7573722F62696E2F6E6F64652D6578706F72746572002D2D636F6C6C6563746F722E626361636865002D2D636F6C6C6563746F722E6370752E696E666F002D2D636F6C6C6563746F722E73797374656D64002D2D636F6C6C6563746F722E73797374656D642E756E69742D696E636C7564653D2E2B5C2E2873657276696365
Nov 26 06:18:45 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: NETDEV WATCHDOG: CPU: 2: transmit queue 0 timed out 30561 ms
Nov 26 06:18:45 cmp221 kernel: mlx5_core 0000:01:00.0 eth-net0: NETDEV WATCHDOG: CPU: 14: transmit queue 2 timed out 30564 ms
Nov 26 06:18:45 cmp221 kernel: mlx5_core 0000:01:00.1 eth-net1: TX timeout detected
Nov 26 06:18:45 cmp221 kernel: mlx5_core 0000:01:00.0 eth-net0: TX timeout detected
From these logs, I have identified several recurring vendor syndrome values. Could you please provide the meaning and recommended actions for the following vendor syndromes:
Vendor Syndrome 0x11
Vendor Syndrome 0x61
Vendor Syndrome 0x51
Vendor Syndrome 0x32
After a couple of hours the card failed with an error
[Wed Nov 26 15:07:33 2025] mlx5_core 0000:01:00.1: poll_health:1066:(pid 0): Fatal error 1 detected
[Wed Nov 26 15:07:33 2025] mlx5_core 0000:01:00.1: print_health_info:491:(pid 0): PCI slot is unavailable
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: poll_health:1066:(pid 0): Fatal error 1 detected
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: print_health_info:491:(pid 0): PCI slot is unavailable
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: SW reset semaphore is already in use
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: mlx5_health_try_recover:347:(pid 86357): handling bad device here
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: mlx5_error_sw_reset:241:(pid 86357): start
[Wed Nov 26 15:07:34 2025] mlx5_core 0000:01:00.0: mlx5_modify_lag:610:(pid 86358): Failed to modify LAG (-67)
[Wed Nov 26 15:07:36 2025] mlx5_core 0000:01:00.0: NIC IFC still 7 after 2000ms.
[Wed Nov 26 15:07:36 2025] mlx5_core 0000:01:00.0: mlx5_error_sw_reset:278:(pid 86357): end
[Wed Nov 26 15:07:44 2025] mlx5_core 0000:01:00.1: mlx5_health_try_recover:347:(pid 83322): handling bad device here
[Wed Nov 26 15:07:45 2025] mlx5_core 0000:01:00.1: mlx5_error_sw_reset:241:(pid 83322): start
[Wed Nov 26 15:07:47 2025] mlx5_core 0000:01:00.1: NIC IFC still 7 after 2000ms.
[Wed Nov 26 15:07:47 2025] mlx5_core 0000:01:00.1: mlx5_error_sw_reset:278:(pid 83322): end
[Wed Nov 26 15:07:47 2025] mlx5_core 0000:01:00.0 eth-net0 (unregistering): mlx5e_set_dev_port_mtu: VPort MTU 65514 is different than netdev mtu 1500
[Wed Nov 26 15:07:47 2025] mlx5_core 0000:01:00.0: mlx5e_execute_l2_action:608:(pid 84910): MPFS, failed to add mac e8:eb:d3:13:48:7a, err(-67)
[Wed Nov 26 15:07:48 2025] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed Nov 26 15:07:48 2025] mlx5_core 0000:01:00.0: mlx5_wait_for_pages:919:(pid 86357): Skipping wait for vf pages stage
[Wed Nov 26 15:07:50 2025] mlx5_core 0000:01:00.0: mlx5_wait_for_pages:919:(pid 86357): Skipping wait for vf pages stage
[Wed Nov 26 15:08:14 2025] mlx5_core 0000:01:00.1 eth-net1 (unregistering): mlx5e_set_dev_port_mtu: VPort MTU 65514 is different than netdev mtu 1500
[Wed Nov 26 15:08:14 2025] mlx5_core 0000:01:00.1: mlx5e_execute_l2_action:608:(pid 86358): MPFS, failed to add mac e8:eb:d3:13:48:7b, err(-67)
[Wed Nov 26 15:08:27 2025] mlx5_core 0000:01:00.1: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed Nov 26 15:08:33 2025] mlx5_core 0000:01:00.1: mlx5_wait_for_pages:919:(pid 83322): Skipping wait for vf pages stage
[Wed Nov 26 15:08:40 2025] mlx5_core 0000:01:00.1: mlx5_wait_for_pages:919:(pid 83322): Skipping wait for vf pages stage
[Wed Nov 26 15:10:10 2025] mlx5_core 0000:01:00.0: mlx5_health_try_recover:350:(pid 86357): health recovery flow aborted, PCI reads still not working
[Wed Nov 26 15:10:43 2025] mlx5_core 0000:01:00.1: mlx5_health_try_recover:350:(pid 83322): health recovery flow aborted, PCI reads still not working
On our side, we will check the PCI slots on the motherboard.
System Information:
Adapter: 2xMellanox ConnectX (0000:01:00.0 and 0000:01:00.1 | 61:00.0 and 61:00.1) Mellanox Technologies Stand-up ConnectX-4 Lx EN, 25GbE dual-port SFP28, PCIe3.0 x8, MCX4121A-ACAT
Driver:
mlx5_core -
Firmware Version: version: 24.10-1.1.4
firmware-version: 14.32.1900 (MT_2420110034) -
Kernel Version: 6.8.0-87-generic
We are also seeing a related error regarding EEPROM access:
mlx5e_get_module_eeprom_by_page: mlx5_query_module_eeprom_by_page failed:0xfffffffb
This leads me to suspect there might be an issue with the hardware, firmware, or a specific driver interaction. Any insight you can provide based on these vendor syndromes would be invaluable in determining our next steps—whether that involves.
