Inquiry on Production-Grade L2+ Stack Options for Aerial 20-Cell Benchmark
Hi jixu,
Thank you for the clarification.
It is helpful to understand that the 20-cell capacity on Grace Hopper was benchmarked with TestMac/U-emulator, as well as with several third-party production-grade L2+ stacks, while the ARC-OTA Aerial Testbed E2E setup with OAI L2+ is not yet intended for 20-cell operation.
May I ask which production-grade L2+ stacks you would recommend for this type of GH200 + Aerial deployment?
We are currently evaluating options and may plan to procure a suitable L2+ stack for our Aerial/AI-RAN testbed. It would be very useful to know:
  1. Which L2+ vendors or stacks have already been validated with Aerial on Grace Hopper;
  2. Whether they support 4T4R, 100 MHz, multi-cell operation close to the 20-cell benchmark;
  3. Whether they have been tested in End-to-End setups with commercial or production-grade O-RUs;
  4. Any recommended vendor contacts or integration partners;
  5. Licensing, delivery model, and typical integration requirements.
Our goal is to move beyond the current OAI-based ARC-OTA testbed and evaluate a more production-grade L2+ solution for higher-capacity multi-cell testing.
Thank you in advance for any recommendation or guidance.
Best regards,
Xudong
Thanks for your questions. The 20-cell result is a peak-performance ACAR benchmark and should not be interpreted as the current capacity of the OAI-based Aerial Testbed.
  1. We have integrated and validated ACAR with Capgemini, OAI, OCUDU and Radisys.
  2. All support 4T4R at 100 MHz. Capgemini was used for the 20-cell 4T4R and single-cell 64T64R peak-throughput scenarios. OAI has been validated with two 4T4R cells, and OCUDU with one 4T4R cell.
  3. Testing included Keysight RuSIM/UeSIM equipment, commercial O-RUs and OTA configurations with commercial UEs. The 20-cell setup used Keysight RuSIM over O-RAN eCPRI fronthaul.
  4. The appropriate vendor depends on your use case. For higher-capacity, production-grade testing beyond the current Aerial Testbed, Capgemini and Radisys are potential options. Capgemini is used in our lab testing for each Aerial release.
  5. Licensing, delivery and integration requirements are vendor-specific and should be discussed directly with the selected provider.
