• Hardware Platform (Jetson / GPU) AGX Orin 64GB Dev-kit
• DeepStream Version DeepStream 7.1
• JetPack Version (valid for Jetson only) JetPack 6.2
• TensorRT Version 10.4
• Issue Type( questions, new requirements, bugs) questions
I am currently developing a GUI application using the DeepStream SDK with Python. I’m still a beginner with DeepStream, and I’m reaching out to ask for your support with an issue I’m facing during development.
The GUI application I am developing currently supports two functionalities:
- A pipeline without
nvinfer - A pipeline with
nvinfer
When I first run the pipeline that includes nvinfer, it works as expected. However, after stopping that pipeline and trying to run the one without nvinfer, the program outputs an error message and then terminates unexpectedly.
I would greatly appreciate any guidance on what might be causing this behavior. For example, is there any additional resource cleanup or initialization required when switching between pipelines in a single application?
By the way, I implemented the memory release part like this:
def create_and_set_pipeline(self, use_ds=False):
if self.pipeline:
self.pipeline.set_state(Gst.State.NULL)
Gst.debug_bin_to_dot_file(self.pipeline, Gst.DebugGraphDetails.ALL, “debug_null”)
for element in self.pipeline.iterate_elements():
element.set_state(Gst.State.NULL)
bus = self.pipeline.get_bus()
if bus:
bus.remove_signal_watch()
bus.set_sync_handler(None)
del self.pipeline
self.pipeline = None
self.sink = None
# 가비지 컬렉션 트리거
gc.collect()
if use_ds:
self.pipeline = create_pipeline_ds(self.cam_list)
else:
self.pipeline = create_pipeline_ori(self.cam_list)
self.sink = self.pipeline.get_by_name('sink')
bus.add_signal_watch()
bus.connect("message", self.on_bus_message)
bus.set_sync_handler(self.on_bus_sync_message)
self.pipeline.set_state(Gst.State.PLAYING)
pipeline with nvifer
v4l2src → capsfilter → videoconvert → nvvideoconvert → capsfilter → queue → streammux
→ queue1
→ nvinfer
→ queue2
→ nvmultistreamtiler
→ queue3
→ nvvideoconvert
→ queue4
→ nv3dsink
pipeline without nvifer
→ queue1
→ queue2
→ nvvideoconvert
→ queue3
→ nv3dsink
If you have any related advice, I would appreciate it!
