Inquiry regarding replacing Ubuntu 24.04 with Ubuntu 22 for the JetPack 7.2 SDK
We are using the JetPack 7.2 SDK, which comes with Ubuntu 24.04. Is it feasible to force‑switch it to Ubuntu 22? What errors or risks may occur if we override it to Ubuntu 22?
You can use JetPack 6.2.3 instead.
After flashing with JetPack 7.2 SDK, we get Ubuntu 24.04. We plan to forcibly replace it with Ubuntu 22. Is this feasible?
No, we never tried that before, don’t know if it’s feasible and the risk; also this is out of our support scope.
Why can’t use JetPack 6.x?
We want to use JetPack 7.2 while also having a stable Ubuntu 22 system.
For better stability, we suggest use clean Jetpack 6.2.3 or 7.2.1. But if you would like to try, you may follow developer guide to upgrade Kernel in Jetpack 6.2.2 from K5.15 to K6.8:
Bring Your Own Kernel — NVIDIA Jetson Linux Developer Guide
