I was running cuda 9 btw.
Couldn’t find any instructions specific to just upgrading to 10.
I skipped to the “run” specific instructions and then added the PATH and LD_LIBRARY_PATH as per the post-install instructions.
Did some of the other libraries change?
Should I install just 410 driver?
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
You should rather use driver packages for your system like rpmfusion so it gets updated along with the system, the .run installers are meant for experienced users with special use cases.
Doesn’t seem like was an option when I first installed the driver some years back.
I’ll look into, though.
So, in my attempt to configure the multi-monitor setup from the Nvidia-Settings window, I seem to have done something that make my mouse only appear over black, before the login screen shows up.
I booted to runlevel 3 and sudo cp the backup over the config (in etc/X11)
no dice.
if I alt-ctrl-F2 it says "A start job is running for Wait for…en to Quit (4 min/nolimit)
With two gpus, you get two different screens. You can move the mouse between them, but nothing else. You can start applications on them using e.g.
DISPLAY=:0.0 glxgears
DISPLAY=:0.1 glxgears
or in case of gnome
DISPLAY=:1.0 glxgears
DISPLAY=:1.1 glxgears
Yes, Xinerama merges those different screens into one logical screen. But you’re losing gl hw accel and compositing that way so only simple window managers will work.
Hey, I had this exact problem and was able to solve it simply by switching from GDM to LightDM, no further Linux surgery required. Just followed the top answer here:
