I need to install CUDA 8.0 and CuDNN 6.0 on a Jetson TX2. I don’t have physical access, only SSH, and I can’t flash Jetpack.
I have tried the following:
- Install JetPack 3.1 in an Ubuntu VM
- Go into the jetpack_download folder and copy all the arm64 packages to the Jetson filesystem via SSH: ``` scp jetpack_download/*arm64.deb jetson0:jetpack_download/ ```
- SSH into the Jetson node and install all the copied packages:
ssh jetson0 cd jetpack_download/ sudo dpkg -i *
- Install CUDA 8.0:
sudo apt update sudo apt install cuda-8-0
But I get an error saying that a package is missing:
$ sudo apt install cuda-8-0
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-8-0 : Depends: cuda-runtime-8-0 (>= 8.0.84) but it is not installable
E: Unable to correct problems, you have held broken packages.
The package cuda-runtime-8-0 is indeed missing from the local CUDA repository. How can I make this installation work?
