Install deepstream 6.01 on nano jetson
**• nano jetson 4g
• DeepStream Version
**• JetPack Version - 4.6.1
**• TensorRT Version- 6.01
Where can i find a link for DS-6.01 installation?
I see only the 6.1 and in the archive i can not found it
BR,
Zvika Shtorch
You can install it via SDK Manager which can be downloaded (NVIDIA SDK Manager | NVIDIA Developer )
Hi
I try to install it in Jetson TX2/Nano ( sdkmanager_1.8.0-10363_amd64.deb)
but i get error message , what i can do?
ome packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdkmanager:amd64 : Depends: libgconf-2-4:amd64 but it is not installable
Depends: libcanberra-gtk-module:amd64 but it is not installable
Depends: locales:amd64 but it is not installable
E: Unable to correct problems, you have held broken packages.
Try sudo apt-get install --fix-missing
10x its working
קבל ‏Outlook עבור Android‏
