I’ve tried to install docker on Jetson TX1 with Ubuntu 14.04 Tegra system
The command sudo apt-get install docker.io doesn’t work.
Could you let me know a way to install docker in the system?
Thank you!
Thank you!
I think 28.2 should be ubuntu 16.04 and already have docker installed.
Thank you for your reply!
If I change my system to 28.2 I would have to move the installations in the current 24.1 system to the new system, which might not work on the new system any more, but I could try that.
Is there a good way to port my current system (24.1) installations to 28.2?
Thank you!
