I just bought a AGX Orin
and when I tried to install dusty-nv inference, there is an error when I type
./cmake
I have attached two files for your reference.
CMakeError.log (4.1 KB)
CMakeOutput.log (42.1 KB)
./cmake
Have you added the --recursive
when cloning the repository?
We can compile the jetson-inference on Orin with the instructions below:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/building-repo-2.md#quick-reference
[ 99%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/controlClassify.cpp.o
[ 99%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/controlWindow.cpp.o
[ 99%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/camera-capture_autogen/mocs_compilation.cpp.o
[ 99%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/captureWindow.cpp.o
[ 99%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/controlDetection.cpp.o
/home/nvidia/jetson-inference/tools/camera-capture/captureWindow.cpp: In member function ‘glWidget* CaptureWindow::GetWidget(int) const’:
/home/nvidia/jetson-inference/tools/camera-capture/captureWindow.cpp:222:1: warning: no return statement in function returning non-void [-Wreturn-type]
222 | }
[100%] Linking CXX executable ../../aarch64/bin/camera-capture
[100%] Built target camera-capture
Yes, I just cut/paste the command…
I am using SDK to flash the Orin. I will tell you the update later.
Thx
OK, if you still have error(s) building jetson-inference, can you please post the terminal output here? Thanks.
Dear Dusty,
yes, it is ok now. thx.
After re-flashing the Orin using SDK manager, I can run the video-viewer /dev/video0
