Install fails since docker.io 20 was released
I had a running clara install which worked like a charm. I updated my computer, including docker.io. This resulted in clara failing. I tried to uninstall and reinstall, but now I get the following error message:
ASK [install-kubernetes : Initialize kubeadm] ************************************************************************************************************************************** fatal: [10.61.72.74]: FAILED! => {"changed": true, "cmd": "kubeadm init --pod-network-cidr=\"10.254.0.0/16\" --apiserver-cert-extra-sans=\"10.61.72.74\" --log-file=/tmp/kubernetes_init.log", "delta": "0:04:27.663437", "end": "2021-11-10 09:35:11.626510", "msg": "non-zero return code", "rc": 1, "start": "2021-11-10 09:30:43.963073", "stderr": "I1110 09:30:44.456885 30504 version.go:252] remote version is much newer: v1.22.3; falling back to: stable-1.19\nW1110 09:30:44.965344 30504 configset.go:348] WARNING: kubeadm cannot validate component configs for API groups [kubelet.config.k8s.io kubeproxy.config.k8s.io]\n\t[WARNING IsDockerSystemdCheck]: detected \"cgroupfs\" as the Docker cgroup driver. The recommended driver is \"systemd\". Please follow the guide at https://kubernetes.io/docs/setup/cri/\n\t[WARNING SystemVerification]: this Docker version is not on the list of validated versions: 20.10.7. Latest validated version: 19.03\nerror execution phase wait-control-plane: couldn't initialize a Kubernetes cluster\nTo see the stack trace of this error execute with --v=5 or higher", "stderr_lines": ["I1110 09:30:44.456885 30504 version.go:252] remote version is much newer: v1.22.3; falling back to: stable-1.19", "W1110 09:30:44.965344 30504 configset.go:348] WARNING: kubeadm cannot validate component configs for API groups [kubelet.config.k8s.io kubeproxy.config.k8s.io]", "\t[WARNING IsDockerSystemdCheck]: detected \"cgroupfs\" as the Docker cgroup driver. The recommended driver is \"systemd\". Please follow the guide at https://kubernetes.io/docs/setup/cri/", "\t[WARNING SystemVerification]: this Docker version is not on the list of validated versions: 20.10.7. Latest validated version: 19.03", "error execution phase wait-control-plane: couldn't initialize a Kubernetes cluster", "To see the stack trace of this error execute with --v=5 or higher"], "stdout": "[init] Using Kubernetes version: v1.19.16\n[preflight] Running pre-flight checks\n[preflight] Pulling images required for setting up a Kubernetes cluster\n[preflight] This might take a minute or two, depending on the speed of your internet connection\n[preflight] You can also perform this action in beforehand using 'kubeadm config images pull'\n[certs] Using certificateDir folder \"/etc/kubernetes/pki\"\n[certs] Generating \"ca\" certificate and key\n[certs] Generating \"apiserver\" certificate and key\n[certs] apiserver serving cert is signed for DNS names [kubernetes kubernetes.default kubernetes.default.svc kubernetes.default.svc.cluster.local omen] and IPs [10.96.0.1 10.61.72.74]\n[certs] Generating \"apiserver-kubelet-client\" certificate and key\n[certs] Generating \"front-proxy-ca\" certificate and key\n[certs] Generating \"front-proxy-client\" certificate and key\n[certs] Generating \"etcd/ca\" certificate and key\n[certs] Generating \"etcd/server\" certificate and key\n[certs] etcd/server serving cert is signed for DNS names [localhost omen] and IPs [10.61.72.74 127.0.0.1 ::1]\n[certs] Generating \"etcd/peer\" certificate and key\n[certs] etcd/peer serving cert is signed for DNS names [localhost omen] and IPs [10.61.72.74 127.0.0.1 ::1]\n[certs] Generating \"etcd/healthcheck-client\" certificate and key\n[certs] Generating \"apiserver-etcd-client\" certificate and key\n[certs] Generating \"sa\" key and public key\n[kubeconfig] Using kubeconfig folder \"/etc/kubernetes\"\n[kubeconfig] Writing \"admin.conf\" kubeconfig file\n[kubeconfig] Writing \"kubelet.conf\" kubeconfig file\n[kubeconfig] Writing \"controller-manager.conf\" kubeconfig file\n[kubeconfig] Writing \"scheduler.conf\" kubeconfig file\n[kubelet-start] Writing kubelet environment file with flags to file \"/var/lib/kubelet/kubeadm-flags.env\"\n[kubelet-start] Writing kubelet configuration to file \"/var/lib/kubelet/config.yaml\"\n[kubelet-start] Starting the kubelet\n[control-plane] Using manifest folder \"/etc/kubernetes/manifests\"\n[control-plane] Creating static Pod manifest for \"kube-apiserver\"\n[control-plane] Creating static Pod manifest for \"kube-controller-manager\"\n[control-plane] Creating static Pod manifest for \"kube-scheduler\"\n[etcd] Creating static Pod manifest for local etcd in \"/etc/kubernetes/manifests\"\n[wait-control-plane] Waiting for the kubelet to boot up the control plane as static Pods from directory \"/etc/kubernetes/manifests\". This can take up to 4m0s\n[kubelet-check] Initial timeout of 40s passed.\n\n\tUnfortunately, an error has occurred:\n\t\ttimed out waiting for the condition\n\n\tThis error is likely caused by:\n\t\t- The kubelet is not running\n\t\t- The kubelet is unhealthy due to a misconfiguration of the node in some way (required cgroups disabled)\n\n\tIf you are on a systemd-powered system, you can try to troubleshoot the error with the following commands:\n\t\t- 'systemctl status kubelet'\n\t\t- 'journalctl -xeu kubelet'\n\n\tAdditionally, a control plane component may have crashed or exited when started by the container runtime.\n\tTo troubleshoot, list all containers using your preferred container runtimes CLI.\n\n\tHere is one example how you may list all Kubernetes containers running in docker:\n\t\t- 'docker ps -a | grep kube | grep -v pause'\n\t\tOnce you have found the failing container, you can inspect its logs with:\n\t\t- 'docker logs CONTAINERID'", "stdout_lines": ["[init] Using Kubernetes version: v1.19.16", "[preflight] Running pre-flight checks", "[preflight] Pulling images required for setting up a Kubernetes cluster", "[preflight] This might take a minute or two, depending on the speed of your internet connection", "[preflight] You can also perform this action in beforehand using 'kubeadm config images pull'", "[certs] Using certificateDir folder \"/etc/kubernetes/pki\"", "[certs] Generating \"ca\" certificate and key", "[certs] Generating \"apiserver\" certificate and key", "[certs] apiserver serving cert is signed for DNS names [kubernetes kubernetes.default kubernetes.default.svc kubernetes.default.svc.cluster.local omen] and IPs [10.96.0.1 10.61.72.74]", "[certs] Generating \"apiserver-kubelet-client\" certificate and key", "[certs] Generating \"front-proxy-ca\" certificate and key", "[certs] Generating \"front-proxy-client\" certificate and key", "[certs] Generating \"etcd/ca\" certificate and key", "[certs] Generating \"etcd/server\" certificate and key", "[certs] etcd/server serving cert is signed for DNS names [localhost omen] and IPs [10.61.72.74 127.0.0.1 ::1]", "[certs] Generating \"etcd/peer\" certificate and key", "[certs] etcd/peer serving cert is signed for DNS names [localhost omen] and IPs [10.61.72.74 127.0.0.1 ::1]", "[certs] Generating \"etcd/healthcheck-client\" certificate and key", "[certs] Generating \"apiserver-etcd-client\" certificate and key", "[certs] Generating \"sa\" key and public key", "[kubeconfig] Using kubeconfig folder \"/etc/kubernetes\"", "[kubeconfig] Writing \"admin.conf\" kubeconfig file", "[kubeconfig] Writing \"kubelet.conf\" kubeconfig file", "[kubeconfig] Writing \"controller-manager.conf\" kubeconfig file", "[kubeconfig] Writing \"scheduler.conf\" kubeconfig file", "[kubelet-start] Writing kubelet environment file with flags to file \"/var/lib/kubelet/kubeadm-flags.env\"", "[kubelet-start] Writing kubelet configuration to file \"/var/lib/kubelet/config.yaml\"", "[kubelet-start] Starting the kubelet", "[control-plane] Using manifest folder \"/etc/kubernetes/manifests\"", "[control-plane] Creating static Pod manifest for \"kube-apiserver\"", "[control-plane] Creating static Pod manifest for \"kube-controller-manager\"", "[control-plane] Creating static Pod manifest for \"kube-scheduler\"", "[etcd] Creating static Pod manifest for local etcd in \"/etc/kubernetes/manifests\"", "[wait-control-plane] Waiting for the kubelet to boot up the control plane as static Pods from directory \"/etc/kubernetes/manifests\". This can take up to 4m0s", "[kubelet-check] Initial timeout of 40s passed.", "", "\tUnfortunately, an error has occurred:", "\t\ttimed out waiting for the condition", "", "\tThis error is likely caused by:", "\t\t- The kubelet is not running", "\t\t- The kubelet is unhealthy due to a misconfiguration of the node in some way (required cgroups disabled)", "", "\tIf you are on a systemd-powered system, you can try to troubleshoot the error with the following commands:", "\t\t- 'systemctl status kubelet'", "\t\t- 'journalctl -xeu kubelet'", "", "\tAdditionally, a control plane component may have crashed or exited when started by the container runtime.", "\tTo troubleshoot, list all containers using your preferred container runtimes CLI.", "", "\tHere is one example how you may list all Kubernetes containers running in docker:", "\t\t- 'docker ps -a | grep kube | grep -v pause'", "\t\tOnce you have found the failing container, you can inspect its logs with:", "\t\t- 'docker logs CONTAINERID'"]}
It appears that ansible installs docker 20, which is unsupported. The ansible task is set to pull docker.io:latest.
Is docker the problem here? In that case, how can I set ansible to install the appropriate docker version?
Best regards
Mathis
