when I build the kernel ,I get the error logs;
make: *** No rule to make target 'modules_install'. Stop.
build steps as follow:
1:$ TEGRA_KERNEL_OUT=/home/kernel_out
2:$ xport CROSS_COMPILE=/opt/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
3:$ export LOCALVERSION=-tegra
4:$ cd kernel/kernel-4.9/
5:$ mkdir -p $TEGRA_KERNEL_OUT
6:$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
7:$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
Here, I have built the kernel successfully,And I try to install the Image to rootf;I do follow steps:
1:root@VM-12-5-ubuntu:~# tar -xjf Jetson-210_Linux_R32.7.1_aarch64.tbz2
2:root@VM-12-5-ubuntu:~# cd Linux_for_Tgera/rootfs
3:root@VM-12-5-ubuntu:~/Linux_for_Tegra/rootfs# sudo tar -jxpf ../../Tegra_Linux_Sample-Root-Filesystem_R32.7.1_aarch64.tbz2
4:root@VM-12-5-ubuntu:~/Linux_for_Tegra/rootfs# cd ..
5:root@VM-12-5-ubuntu:~/Linux_for_Tegra# sudo ./apply_binaries.sh
6:root@VM-12-5-ubuntu:~/Linux_for_Tegra# cp /home/kernel_out/arch/arm64/boot/Image kernel/Image
7:root@VM-12-5-ubuntu:~/Linux_for_Tegra# cp -r /home/kernel_out/arch/arm64/boot/dts/* kernel/dtb/
8:root@VM-12-5-ubuntu:~/Linux_for_Tegra# sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install ~/Linux_for_Tegra/rootfs/
When I execute the final step ,I get the error log:
I do not know how to solve this probems…
