sudo apt-get install nvidia-gds
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
nvidia-gds is already the newest version (12.5.0-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up linux-modules-nvidia-530-5.19.0-1014-nvidia-64k (5.19.0-1014.14) …
linux-image-nvidia-5.19.0-1014-nvidia-64k: constructing .ko files
nvidia-drm.ko: OK
nvidia-modeset.ko: OK
nvidia-peermem.ko: OK
nvidia-uvm.ko: OK
nvidia.ko: FAILED
sha256sum: WARNING: 1 computed checksum did NOT match
dpkg: error processing package linux-modules-nvidia-530-5.19.0-1014-nvidia-64k (–configure):
installed linux-modules-nvidia-530-5.19.0-1014-nvidia-64k package post-installation script subprocess returned error exit status 1
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of linux-modules-nvidia-530-nvidia-64k-5.19:
linux-modules-nvidia-530-nvidia-64k-5.19 depends on linux-modules-nvidia-530-5.19.0-1014-nvidia-64k (= 5.19.0-1014.14); however:
Package linux-modules-nvidia-530-5.19.0-1014-nvidia-64k is not configured yet.
dpkg: error processing package linux-modules-nvidia-530-nvidia-64k-5.19 (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-fs-dkms:
nvidia-fs-dkms depends on cuda-drivers-grid | nvidia-prebuilt-kernel | nvidia-dkms-kernel | nvidia-kernel-dkms; however:
Package cuda-drivers-grid is not installed.
Package nvidia-prebuilt-kernel is not installed.
Package linux-modules-nvidia-530-nvidia-64k-5.19 which provides nvidia-prebuilt-kernel is not configured yet.
Package nvidia-dkms-kernel is not installed.
Package nvidia-kernel-dkms is not installed.
dpkg: error processing package nvidia-fs-dkms (–configure):
dependency problemNo apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of nvidia-fs:
nvidia-fs depends on nvidia-fs-prebuilt (>= 2.20.5) | nvidia-fs-dkms (>= 2.20.5); however:
Package nvidia-fs-prebuilt is not installed.
Package nvidia-fs-dkms is not configured yet.
dpkg: error processing package nvidia-fs (–configure):
dpkg: dependency problems prevent configuration of nvidia-gds-12-5:
nvidia-gds-12-5 depends on nvidia-fs (>= 2.20.5); however:
Package nvidia-fs is not configured yet.
dpkg: error processing package nvidia-gds-12-5 (–configure):
dpkg: dependency problems prevent configuration of nvidia-gds:
nvidia-gds depends on nvidia-gds-12-5 (>= 12.5.0); however:
Package nvidia-gds-12-5 is not configured yet.
dpkg: error processing package nvidia-gds (–configure):
Errors were encountered while processing:
nvidia-fs-dkms
nvidia-fs
nvidia-gds-12-5
nvidia-gds
E: Sub-process /usr/bin/dpkg returned an error code (1)
