Install nvidia rtx2000 a driver in ACRN's guest vm
This is the corresponding log generated by installing the nvidia driver. I use sudo sh NVIDIA-Linux-x86_ The 64 xxxx. run – kernel source path=/usr/src/Linux headers - $(uname - r) command was installed
nvidia-installer.log (38.2 KB)
The following error occurred:
Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA device(s), or no NVIDIA device installed in this system is supported by this NVIDIA Linux graphics driver release.
