Install of NVIDIA AI Workbench on Ubuntu Failed - App Error
type: ‘app_error’,
data: { message: ‘Something went wrong please restart your installer’ }
main.log (192.2 KB)
Can’t figure out what’s wrong. Tried with and without sandbox. Thanks
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Hi, thanks for reaching out. From the logs it looks like something to do with the git-xet state. This is a little strange as AI Workbench does not current support XetHub.
[2024-09-08 22:13:56.279] [error] (check-host) Command failed: /home/jason/.nvwb/bin/wb-svc info
an error occurred while checking server info. try again: failed to load host state: Failed to check git-xet state: bash: line 1: git: command not found
I’ll forward this issue over to Engineering and get back to you when I get a response.
So it appears that line is an artifact that should not interfere with the install process. What is potentially happening here is both git-xet and git itself may be missing and that the latter is what is causing the error.
You can try a manual git install to see if that resolves this git command not found error.
I will try. Chuckle at the “should not interfere,” but clearly it did!
