Trying to install OpenMAX so that I can use gst-launch-1.0 (with gstreamer).
The command I’m trying to run is:
gst-launch-1.0 filesrc location="LOCATIONHERE.mp4" ! qtdemux name=demux ! h264parse ! omxh26dec ! nvoverlaysink -e
But I get the following error:
libEGL warning: DRI2: failed to authenticate
libEGL warning: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)libEGL warning: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
nvbuf_utils: Could not get EGL display connection
WARNING: erroneous pipeline: no element “nvoverlaysink”
Caught SIGSEGV
exec gdb failed: No such file or directory
This is all after installing gstreamer successfully, and after having installed the libegl dependency,
but gstomx1 will not compile/install. It gives the following error:
I received the files from (for Jetson NX): https://developer.nvidia.com/embedded/L4T/r32_Release_v4.2/Sources/T186/public_sources.tbz2
I’m doing everything under 32.4.2
root@9cc23b3:~/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1# make
make all-recursive
make[1]: Entering directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1’
Making all in common
make[2]: Entering directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common’
Making all in m4
make[3]: Entering directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common/m4’
make[3]: Nothing to be done for ‘all’.
make[3]: Leaving directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common/m4’
make[3]: Entering directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common’
make[3]: Nothing to be done for ‘all-am’.
make[3]: Leaving directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common’
make[2]: Leaving directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/common’
Making all in omx
make[2]: Entering directory ‘/root/Linux_for_Tegra/source/public/gstomx1_src/gst-omx1/omx’
CC libgstomx_la-gstomxvideosink.lo
gstomxvideosink.c:30:10: fatal error: nvbufsurface.h: No such file or directory
include “nvbufsurface.h”
compilation terminated.
Additional notes:
Doing this inside of a Balena container. I’ve been able to get all of the other GPU libs working. This is the last thing.
