I just recently received my s870 and man is it huge and loud! I am using a quad core 2 machine with 790i sli ultra motherboard and gx2 9800 gpu.
w/ the 9800 and the s870 hardware installed, I installed the latest NVIDIA driver lisedt under the s870 while under init3 with the following command:
./NVIDIA-Linux-x86-171.06.01-pkg1.run
I then modified my GRUB menu.lst as mentioned here on this forum by adding the following lines:
uppermem 524288
vmalloc=256MB
pci=nommconf
I restarted the machine and performed the following checks with the 9800 and s870 installed:
# lspci | grep 3D
03:00.0 3D controller: nVidia Corporation Unknown device 0604 (rev a2)
0b:00.0 3D controller: nVidia Corporation Unknown device 0197 (rev a2)
0d:00.0 3D controller: nVidia Corporation Unknown device 0197 (rev a2)
18:00.0 3D controller: nVidia Corporation Unknown device 0197 (rev a2)
1a:00.0 3D controller: nVidia Corporation Unknown device 0197 (rev a2)
ls -l /dev/nv*
crw-rw---- 1 root video 195, 0 2008-07-24 09:50 /dev/nvidia0
crw-rw---- 1 root video 195, 1 2008-07-24 09:50 /dev/nvidia1
crw-rw---- 1 root video 195, 2 2008-07-24 09:50 /dev/nvidia2
crw-rw---- 1 root video 195, 3 2008-07-24 09:50 /dev/nvidia3
crw-rw---- 1 root video 195, 4 2008-07-24 09:50 /dev/nvidia4
crw-rw---- 1 root video 195, 5 2008-07-24 09:50 /dev/nvidia5
crw-rw---- 1 root video 195, 255 2008-07-24 09:50 /dev/nvidiactl
# ./deviceQuery
NVIDIA: could not open the device file /dev/nvidia2 (Input/output error).
There is no device supporting CUDA.
Device 0: "Device Emulation (CPU)"
Major revision number: 9999
Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Test PASSED
Press ENTER to exit...
I then powered down the computer and disconnected the s870 to see what results I had with the 9800. I then performed the same actions as above:
# lspci | grep 3D
# ls -l /dev/nv*
crw-rw---- 1 root video 195, 0 2008-07-24 09:27 /dev/nvidia0
crw-rw---- 1 root video 195, 1 2008-07-24 09:27 /dev/nvidia1
crw-rw---- 1 root video 195, 255 2008-07-24 09:27 /dev/nvidiactl
# ./deviceQuery
There are 2 devices supporting CUDA
Device 0: "G92-450"
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 536543232 bytes
Warp size: 32
Clock rate: 1.51 GHz
Concurrent copy and execution: Yes
Device 1: "G92-450"
Total amount of global memory: 536608768 bytes
Warp size: 32
Test PASSED
Everything worked! Does anybody have any insight on what the problem may be? I should also mention that this is a fresh install of openSUSE 10.3
Thanks for you time!
