i installed librosa by following the link method below but got a bit of eros.
copying numba/tests/npyufunc/test_errors.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_low_work.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_ufunc_issues.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufunc.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_vectorize_decor.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_caching.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_gufunc.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_env_variable.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/cache_usecases.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/init.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools_nested.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/source_module.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils_nested.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/init.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/source_module.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/init.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
creating build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/service.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/init.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/threadlocal.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
creating build/lib.linux-aarch64-3.6/numba/roc/tests
copying numba/roc/tests/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests
creating build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/drvapi.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums_ext.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devices.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/error.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devicearray.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/driver.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/init.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
creating build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/common.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/config.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/libhlc.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/init.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/hlc.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_simple.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/run_far_branch.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_reduction.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_positioning.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_linkage.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_compiler.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_intrinsics.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_ufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_barrier.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_atomics.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_occupancy.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_async_kernel.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_matmul.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_memory.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_large_code.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_math.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_scan.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_autojit.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_gufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_decorator.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_driver.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_async.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
creating build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/numbers.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/tuple.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/init.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
creating build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/inspector.py → build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/init.py → build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/_helpermod.c → build/lib.linux-aarch64-3.6/numba
copying numba/_npymath_exports.c → build/lib.linux-aarch64-3.6/numba
copying numba/_lapack.c → build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.c → build/lib.linux-aarch64-3.6/numba
copying numba/_random.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dynfuncmod.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dispatcher.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dynfunc.c → build/lib.linux-aarch64-3.6/numba
copying numba/mviewbuf.c → build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.c → build/lib.linux-aarch64-3.6/numba
copying numba/_helperlib.c → build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.h → build/lib.linux-aarch64-3.6/numba
copying numba/_dispatcher.h → build/lib.linux-aarch64-3.6/numba
copying numba/_numba_common.h → build/lib.linux-aarch64-3.6/numba
copying numba/capsulethunk.h → build/lib.linux-aarch64-3.6/numba
copying numba/_unicodetype_db.h → build/lib.linux-aarch64-3.6/numba
copying numba/mathnames.h → build/lib.linux-aarch64-3.6/numba
copying numba/_pymodule.h → build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.h → build/lib.linux-aarch64-3.6/numba
copying numba/_arraystruct.h → build/lib.linux-aarch64-3.6/numba
copying numba/cext/listobject.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/dictobject.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/utils.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/dictobject.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/listobject.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/cext.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/pycc/modulemixin.c → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/misc/cmdlang.gdb → build/lib.linux-aarch64-3.6/numba/misc
copying numba/core/runtime/_nrt_pythonmod.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/_nrt_python.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.h → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt_external.h → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/annotations/template.html → build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/cuda/tests/cudadrv/data/jitlink.ptx → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
running build_ext
building ‘numba._dynfunc’ extension
Warning: Can’t read registry to find the necessary compiler setting
Make sure that Python modules winreg, win32api or win32con are installed.
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/numba
compile options: '-I/usr/include/python3.6m -c'
extra options: '-g'
aarch64-linux-gnu-gcc: numba/_dynfuncmod.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dynfuncmod.o -o build/lib.linux-aarch64-3.6/numba/_dynfunc.cpython-36m-aarch64-linux-gnu.so
building 'numba._dispatcher' extension
creating build/temp.linux-aarch64-3.6/numba/core
creating build/temp.linux-aarch64-3.6/numba/core/typeconv
compile options: '-I/usr/local/lib/python3.6/dist-packages/numpy/core/include -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/_dispatcher.c
aarch64-linux-gnu-gcc: numba/_typeof.c
aarch64-linux-gnu-gcc: numba/_hashtable.c
aarch64-linux-gnu-gcc: numba/_dispatcherimpl.cpp
aarch64-linux-gnu-gcc: numba/core/typeconv/typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dispatcher.o build/temp.linux-aarch64-3.6/numba/_typeof.o build/temp.linux-aarch64-3.6/numba/_hashtable.o build/temp.linux-aarch64-3.6/numba/_dispatcherimpl.o build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o -L/usr/local/lib/python3.6/dist-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_dispatcher.cpython-36m-aarch64-linux-gnu.so
building 'numba._helperlib' extension
creating build/temp.linux-aarch64-3.6/numba/cext
extra options: '-g'
aarch64-linux-gnu-gcc: numba/_helpermod.c
aarch64-linux-gnu-gcc: numba/cext/utils.c
aarch64-linux-gnu-gcc: numba/cext/dictobject.c
aarch64-linux-gnu-gcc: numba/cext/listobject.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_helpermod.o build/temp.linux-aarch64-3.6/numba/cext/utils.o build/temp.linux-aarch64-3.6/numba/cext/dictobject.o build/temp.linux-aarch64-3.6/numba/cext/listobject.o -L/usr/local/lib/python3.6/dist-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_helperlib.cpython-36m-aarch64-linux-gnu.so
building 'numba.core.typeconv._typeconv' extension
aarch64-linux-gnu-gcc: numba/core/typeconv/_typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o build/temp.linux-aarch64-3.6/numba/core/typeconv/_typeconv.o -o build/lib.linux-aarch64-3.6/numba/core/typeconv/_typeconv.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc._internal' extension
creating build/temp.linux-aarch64-3.6/numba/np
creating build/temp.linux-aarch64-3.6/numba/np/ufunc
aarch64-linux-gnu-gcc: numba/np/ufunc/_internal.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_internal.o -L/usr/local/lib/python3.6/dist-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_internal.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc._num_threads' extension
aarch64-linux-gnu-gcc: numba/np/ufunc/_num_threads.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_num_threads.o -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_num_threads.cpython-36m-aarch64-linux-gnu.so
building 'numba.mviewbuf' extension
aarch64-linux-gnu-gcc: numba/mviewbuf.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/mviewbuf.o -o build/lib.linux-aarch64-3.6/numba/mviewbuf.cpython-36m-aarch64-linux-gnu.so
building 'numba.core.runtime._nrt_python' extension
creating build/temp.linux-aarch64-3.6/numba/core/runtime
aarch64-linux-gnu-gcc: numba/core/runtime/_nrt_pythonmod.c
aarch64-linux-gnu-gcc: numba/core/runtime/nrt.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/runtime/_nrt_pythonmod.o build/temp.linux-aarch64-3.6/numba/core/runtime/nrt.o -L/usr/local/lib/python3.6/dist-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/core/runtime/_nrt_python.cpython-36m-aarch64-linux-gnu.so
building 'numba.experimental.jitclass._box' extension
creating build/temp.linux-aarch64-3.6/numba/experimental
creating build/temp.linux-aarch64-3.6/numba/experimental/jitclass
aarch64-linux-gnu-gcc: numba/experimental/jitclass/_box.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/experimental/jitclass/_box.o -o build/lib.linux-aarch64-3.6/numba/experimental/jitclass/_box.cpython-36m-aarch64-linux-gnu.so
building 'numba.cuda.cudadrv._extras' extension
creating build/temp.linux-aarch64-3.6/numba/cuda
creating build/temp.linux-aarch64-3.6/numba/cuda/cudadrv
compile options: '-Inumba -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: numba/cuda/cudadrv/_extras.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.o -o build/lib.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.cpython-36m-aarch64-linux-gnu.so
building 'numba.np.ufunc.tbbpool' extension
compile options: '-I/usr/include -I/usr/include/python3.6m -c'
extra options: '-std=c++11'
aarch64-linux-gnu-gcc: numba/np/ufunc/tbbpool.cpp
aarch64-linux-gnu-gcc: numba/np/ufunc/gufunc_scheduler.cpp
numba/np/ufunc/tbbpool.cpp:30:2: error: #error "TBB version is too old, 2019 update 5, i.e. TBB_INTERFACE_VERSION >= 11005 required"
numba/np/ufunc/tbbpool.cpp: In constructor ‘fix_tls_observer::fix_tls_observer(tbb::interface7::task_arena&, int)’:
numba/np/ufunc/tbbpool.cpp:89:108: error: no matching function for call to ‘tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(tbb::interface7::task_arena&)’
fix_tls_observer(tbb::task_arena &arena, int mask) : tbb::task_scheduler_observer(arena), mask_val(mask)
In file included from /usr/include/tbb/tbb.h:79:0,
from numba/np/ufunc/tbbpool.cpp:15:
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate: tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3()
task_scheduler_observer_v3() : my_proxy(NULL) { my_busy_count.store<relaxed>(0); }
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate expects 0 arguments, 1 provided
/usr/include/tbb/task_scheduler_observer.h:40:7: note: candidate: constexpr tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(const tbb::internal::task_scheduler_observer_v3&)
class task_scheduler_observer_v3 {
/usr/include/tbb/task_scheduler_observer.h:40:7: note: no known conversion for argument 1 from ‘tbb::interface7::task_arena’ to ‘const tbb::internal::task_scheduler_observer_v3&’
error: Command "aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include -I/usr/include/python3.6m -c numba/np/ufunc/tbbpool.cpp -o build/temp.linux-aarch64-3.6/numba/np/ufunc/tbbpool.o -std=c++11" failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-v8f_be6s/numba/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-v8f_be6s/numba/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-kb874o3d/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/nvidia/.local/include/python3.6m/numba Check the logs for full command output.
