Hi everyone,
I’ve been trying to install pytorch in one of my TX1’s so I can replicate the process and isntall it in the others (have several, all TX1), but I just can’t find a way to do it.
I’ve encountered several errors, even tried to do it with the source code.
Is there any way, manual or tutorial to do it?
Thanks a lot.
Hi psmosquera, have you tried the pip wheels from this post?
https://devtalk.nvidia.com/default/topic/1049071/jetson-nano/pytorch-for-jetson-nano-version-1-3-0-now-available/
If you get errors from those, can you post them here? Thanks.
Within the sdk manager (to flash the TX1) I have two options:
- Install the “Jetson SDK Components” (CUDa, AI Computer Vision, NVIDIA Container Runtime and Multimedia) and end up with 3.4gb of free storage, or
- Don’t install “Jetson SDK Components”, end up with 10.4gb of free storage and install CUDA manually.
Couldnt find a way to install CUDA for TX1’s aarch64, any help with that?
Succesfully installed numpy and torch but having trouble with torchvision
Installation of numpy and torch
nvidia@nvidiaA:~$ pip3 install numpy torch-1.3.0-cp36-cp36m-linux_aarch64.whl
Collecting numpy
Downloading https://files.pythonhosted.org/packages/b6/d6/be8f975f5322336f62371c9abeb936d592c98c047ad63035f1b38ae08efe/numpy-1.17.3.zip (6.4MB)
100% |████████████████████████████████| 6.4MB 96kB/s
Processing ./torch-1.3.0-cp36-cp36m-linux_aarch64.whl
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy ... done
Stored in directory: /home/nvidia/.cache/pip/wheels/5e/e9/4b/dd5a8eb53e97dfcc1314eca9c6769edd3cad379d6644c1ad94
Successfully built numpy
Installing collected packages: numpy, torch
Successfully installed numpy-1.17.3 torch-1.3.0
Trouble finding module
nvidia@nvidiaA:~$ cd torchvision
nvidia@nvidiaA:~/torchvision$ sudo python setup.py install
File "setup.py", line 14, in <module>
import torch
ImportError: No module named torch
Could you try it with python3 ?
nvidia@nvidiaA:~/torchvision$ sudo <b>python3</b> setup.py install
Thanks AastaLLL, already found a way, installed some libraries, python3-dev, python3-setuptools, Pillow (for pip and pip3) and finally that setup.py with python3.
But I need help with this:
If you could help me out, it would be awesome,
Thanks a lot.
You can find the CUDA package in the download folder.
By default it should be${home}/Downloads/nvidia/sdkm_downloads.
Then, copy the CUDA toolkit into the device and manually dpkg install it.
