Hey everyone,
I’ve installed Jetson OS L4T 32.5.0, i’am wondering if it’s possible to install the version of the tegra multimedia API 32.2.0 in this version of Jetson Linux OS ?
For example :
sudo apt install nvidia-l4t-jetson-multimedia-api <version>
Can you please tell me if that is possible and compatible ? If yes what’s the reference of tegra mmapi of the 32.2.0 ?
On r32.5.0, please install jetson_multimedi_api samples through SDKManager. It is in SDK components.
Hi @DaneLLL ,
Thanks you for your answer, but what i want is to use tegra mmapi 32.2.0 in L4T 32.5.0, if i use sdkmanager the tegra 32.5.0 will be installed.
We have seen issues when version of system and jetson_multimedia_api mismatches. Would suggest you use the identical version.
system
closed
July 27, 2022, 2:26am
#7
