I try theese command to install driver:
sudo apt install git dkms
git clone -b v5.6.1 https://github.com/fastoe/RTL8812BU_for_Raspbian
cd RTL8812BU_for_Raspbian
ubuntu@EAC-6000:~/workspaces/RTL8812BU_for_Raspbian$ make ARCH=arm64
make ARCH=arm64 CROSS_COMPILE= -C /lib/modules/5.10.104-tegra/build M=/home/ubuntu/workspaces/RTL8812BU_for_Raspbian modules
make[1]: Entering directory '/usr/src/linux-headers-5.10.104-tegra-ubuntu20.04_aarch64/kernel-5.10'
ERROR: Kernel configuration is invalid.
include/generated/autoconf.h or include/config/auto.conf are missing.
Run 'make oldconfig && make prepare' on kernel src to fix it.
Makefile:675: include/config/auto.conf: No such file or directory
make[1]: *** [Makefile:750: include/config/auto.conf] Error 1
make[1]: Leaving directory '/usr/src/linux-headers-5.10.104-tegra-ubuntu20.04_aarch64/kernel-5.10'
make: *** [Makefile:2284: modules] Error 2
ubuntu@EAC-6000:~/workspaces/RTL8812BU_for_Raspbian$ ls /boot/config-$(uname -r)
ls: cannot access '/boot/config-5.10.104-tegra': No such file or directory
How can I install driver on Jetpcak 5.1.1?
thanks!
Jetson Info:
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin - Jetpack 5.1.1 [L4T 35.3.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
- Module: Check with sudo
Platform:
- Distribution: Ubuntu 20.04 focal
- Release: 5.10.104-tegra
jtop:
- Version: 4.2.12
- Service: Active
Libraries:
- CUDA: 11.4.315
- cuDNN: 8.6.0.166
- TensorRT: 8.5.2.2
- VPI: 2.2.7
- Vulkan: 1.3.204
- OpenCV: 4.10.0 - with CUDA: YES
