Hi. I can not install Ubuntu 20 to Jetson xavier nx
please follow this method to dump the error during flash from the device side.
That thing is just guide you how to dump log. Of course it didn’t fix anything…
What I need here is share the full log as text log file here…
I’m not sure I understood correctly which text log is needed. But after starting the “minicom” and connecting power to jetson, a repeating set of messages is output to the terminal:
[0000.114] I> Reset to recovery mode
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.033] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x0
[0000.059] I> rst_source : 0xa
[0000.062] I> rst_level : 0x1
[0000.065] E> Failed to verify PMC high threshold fault occurence. Fault reg: 02
[0000.072] E> Task 16 failed (err: 0x77770118)
[0000.076] E> Top caller module: CVMON, error module: CVMON, reason: 0x18, aux_1
[0000.084] I> MB1(1.5.1.7-t194-41334769-98030a79) BIT boot status dump :
00000000000111111000000000000000000000000000000000000000000000000000000000000000
text_log.txt (1.4 KB)
Are you using NV devkit to test here? The error log looks like problem from hardware side.
Also, did you ever flash this board before?
Yes, I am using the model P3518 to install software on my jetson xavier nx. I’m trying to install software on MMC. And yes, this board has worked before. Now I have gone through the installation cycle again and recorded the output of “minicom” in log.txt
log.txt (1023.1 KB)
How did this board work before? Any specific jetpack version to flash it?
Jetpack 5.1.1 used to be on it. Now I’m trying to install version 5.1.4, since version 5.1.1 is no longer available in the SDK Manager.
Jetpack5.1.1 is still available. Please run with
sdkmanager --archived-versions
I launched the archived version of the SDK Manager, but got the same error.
log.txt (1.3 MB)
Stop sharing screenshot. You only need to share uart serial log as what we just taught you.
Then please RMA this device. It is hardware defect.
