Install USD Composer and stop the omi.create.warmup.bat file
By the way, my installation with administrator privileges still does not work
Can you please restart your computer completely and try again with the new 2023.2.5 with NO other software running please. The warmup sequence can take as long as 10 mins.
Still can’t work.
Ok. Can you be more specific and describe exactly what is happening ? When exactly does it fail ? What is your system specs ? Can you please provide the Launcher logs showing the install failure.
Have you ever managed to install any version of composer ? Can you try to install Issac sim and Presenter and see if they install ?
