I got my Licensing Instructions today, but I can not get my Hostname nore my FLEXnet hostid
When I issue the following command at a shell prompt:
% lmutil lmhostid
I am getting:
$ /opt/pgi/linux86-64/15.7/bin $ lmutil lmhostid
bash: /opt/pgi/linux86-64/15.7/bin/lmutil: No such file or directory
All the software is pgi installed and working with a temporary license.
Can some one help me?
tull
2
The 15.* compilers and newer use new versions of flexlm that require
‘Linux Standard Base’ , aka ‘lsb’ be present.
The most common symptom of the problem will be
a message when you run the compilers
$PGI/linux86-64/15.*/bin/lmutil: No such file or directory
To determine if the problem is lsb, type
% lsb_release
if it returns core-3.0 or higher, you have lsb.
If less than 3.0 or ‘n/a’ is returned, you need to install it,
and then run the compilers.
For ubuntu, the process is
% apt-get install lsb
on other Linux versions, you need to find the rpm and
install it.
dave
