Im trying to flash agx xavier dev kit but I get the same error in ‘step 04’ everytime, the error is 'INSTALLATION FAILED please review the terminal tab for details. Resolve and RETRY. Flash of target hardware was skipped.
Failed Component: VPI on Host. Error: (APT system is broken and requires manual fix).
I have connected the jetson device to internet via Ethernet cable, and connecting my laptop to wifi (but same internet). The laptop wifi disconnect sometimes and shifts to the Ethernet of the agx (because they are connected).
I didn’t find the original type C cable of jetson, so I used another type C cable but I checked lsusb and it was detected (it was in the list).
I started from step01 and this time I select another version of jetpack and unselect the deepstream option. this time I got error for CUDA and Computer Vision. and the installation failed.
side not: in all tries in step 03 when it is asked to write our user and pass, there, it is written that ‘no board detected’ I refresh, and another block beside it containing the name of my jetson device appears. then I continue.
Thanks for the reply.
I used exactly the same port as in the picture (next to the power LED).
And I checked the $ lsusb in terminal on the host computer and the agx xavier ID was there, it means it was connected.
Is there any other possible mistake or problem?
to connect the jetson device to the host, is it possible to use micro USB port instead of usb type C?
No I never used that port. But I have flashed the device several times and never faced this restrict installation failed. I was getting failed for some packages but by RETRY they were getting fixed, at that times I was using original usb type C of the device.
I have another question:
In some of the tries when I face installation error, I go back to step 01 and start again from beginning, in the step 03 some files will be downloaded into the two specified path/directory. Do they get overwritten each time or I have to delete the downloaded files from the previous try?
There is a “export logs” button on your sdkmanager, when the error happens, click that button and share the log.
From your comment “Failed Component: VPI on Host. Error: (APT system is broken and requires manual fix).”, I can only guess the issue does not happen to jetson now, the issue is due to your host machine apt-get update has error from the beginning.
SDKM detects such error in your apt-get so it just aborted.
I found the original cable and tried to flash it again both to test the cable and send you the export log, but this time I got error in STEP02.
I attached the screenshot below.
what should I do?
Would you please help ASAP, I am in hurry.
We have no idea about this because it looks like your own apt-get issue. Not from sdkmanager.
Make it more easier to understand, your apt-get update on your host machine is broken from the beginning.
