Installation incomplete. Clock is behind
My network time doesn’t seem to work correctly. Therefor, when I flash and install the TX2
through Jetpack 3.0, the installation doesn’t complete 100% and some of the software is not installed
because the clock is far behind (2016 instead of 2017, etc).
How can I fix this ?
After flashing the OS, I don’t see that there is enough time to quickly fix the clock manually and then continue with the installation.
On both host and Jetson (if it is running), what is the output of:
timedatectl status
FYI, ntp uses port 123, it is possible a firewall has blocked the port (e.g., if your Ubuntu host is used as a router it probably runs some firewall software by default).
