The base docker build works, it is the second step that fails when running
docker build -t ipp
Step 7/11 : RUN jupyter nbextension enable --py --sys-prefix ipyparaview
—> Running in dfcb4f90f526
Enabling notebook extension ipyparaview/extension…
- Validating: OK
Removing intermediate container dfcb4f90f526
—> 78d76d654ccc
Step 8/11 : RUN jupyter labextension install js
—> Running in 66f0cda8d488
An error occured.
ValueError: Please install nodejs >=10.0.0 before continuing. nodejs may be installed using conda or directly from the nodejs website.
See the log file for details: /tmp/jupyterlab-debug-t810vtv8.log
The command ‘/bin/bash -c jupyter labextension install js’ returned a non-zero code: 1
