Hello there.
I was exploring the jetson nano image till now. Now i want to explore jetbot image. My question is will i loose my previous files/configuration on jetson nano image if i install jetbot image?
Hello there.
I’m not sure what image you’re talking about, using SD card image?
If you want to use JetBot with an existing Jetson Nano SD card image, maybe you should use the pre-built JetBot docker container.
B&R
