I installed ubuntu 14.04.5 on VMware, and then created a share folder /mnt/hgfs/TF, and saved the JetPack L4T installation package in this shared directory.
Then I tried to install JetPack L4T on ubuntu 14.04.5. However, the installation always failed due to “open /mnt/hgfs/TF/JetPack//_installer/tmp/jetpackfifo: no such file or directory”.
I check the directory, jetpackfifo_req is successfully created, but jetpackfifo is never created.
Could anyone tell me how solve this problem? Thank you for your advice in advance.
************************************ The followings are the log information. ************************************
starting sudo daemon
sudo /mnt/hgfs/TF/JetPack//_installer/sudo_daemon -installer=12371 -d=/mnt/hgfs/TF/JetPack//_installer/tmp
/mnt/hgfs/TF/JetPack//_installer/run_command -c=“/mnt/hgfs/TF/JetPack/jetpack_download/NVIDIA_Tegra_Graphics_Debugger_2.2.16124.1931_Release_External_tgd-l4t_linux-l4t.run --nox11 – -noprompt” -d=/mnt/hgfs/TF/JetPack//_installer/tmp -l=/mnt/hgfs/TF/JetPack/_installer/logs//install_tegra_graphics_debugger.log
2.6.20651219-linux-x64/Host-x86_64/CrashReporter
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/ClearLogs.png
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/LogIcon_Error.png
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/LogIcon_Fatal.png
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/LogIcon_Info.png
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/LogIcon_Warning.png
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/Manifest.js
2.6.20651219-linux-x64/Host-x86_64/Plugins/CorePlugin/libCorePlugin.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/QuadDPlugin/Manifest.js
2.6.20651219-linux-x64/Host-x86_64/Plugins/QuadDPlugin/libInterface.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/accessible/libqtaccessiblewidgets.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqgif.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqico.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqjpeg.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqmng.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqsvg.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqtga.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqtiff.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/imageformats/libqwbmp.so
2.6.20651219-linux-x64/Host-x86_64/Plugins/platforms/libqxcb.so
2.6.20651219-linux-x64/Host-x86_64/ResolveSymbols
2.6.20651219-linux-x64/Host-x86_64/TegraProfiler.png
2.6.20651219-linux-x64/Host-x86_64/TegraSystemProfiler
2.6.20651219-linux-x64/Host-x86_64/TegraSystemProfiler.bin
2.6.20651219-linux-x64/Host-x86_64/libAppLib.so
2.6.20651219-linux-x64/Host-x86_64/libNvLogShared.so
2.6.20651219-linux-x64/Host-x86_64/libQt5CLucene.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Concurrent.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Core.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5DBus.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Declarative.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Designer.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5DesignerComponents.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Gui.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Help.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Multimedia.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5MultimediaQuick_p.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5MultimediaWidgets.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Network.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5OpenGL.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Positioning.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5PrintSupport.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Qml.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Quick.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5QuickParticles.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5QuickTest.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Script.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5ScriptTools.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Sensors.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Sql.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Svg.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Test.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5WebKit.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5WebKitWidgets.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Widgets.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5Xml.so.5
2.6.20651219-linux-x64/Host-x86_64/libQt5XmlPatterns.so.5
2.6.20651219-linux-x64/Host-x86_64/libQtPropertyBrowser.so
2.6.20651219-linux-x64/Host-x86_64/libSymbolDemangler.so
2.6.20651219-linux-x64/Host-x86_64/libcrypto.so.1.0.0
2.6.20651219-linux-x64/Host-x86_64/libicudata.so.42
2.6.20651219-linux-x64/Host-x86_64/libicui18n.so.42
2.6.20651219-linux-x64/Host-x86_64/libicuuc.so.42
2.6.20651219-linux-x64/Host-x86_64/libssl.so.1.0.0
2.6.20651219-linux-x64/Host-x86_64/libudev.so.0
2.6.20651219-linux-x64/Host-x86_64/nvlog.config.template
2.6.20651219-linux-x64/Host-x86_64/tegra-system-profiler.desktop.template
2.6.20651219-linux-x64/Target-arm-linux/armv7/launcher
2.6.20651219-linux-x64/Target-arm-linux/armv7/libBw32.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libLauncher32.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjection32.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjectionCudaInt32_6_5.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjectionCudaInt32_7_0.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjectionCudaInt32_7_5.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjectionCudaInt32_8_0.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libToolsInjectionProxy32.so
2.6.20651219-linux-x64/Target-arm-linux/armv7/libnvToolsExt.a
2.6.20651219-linux-x64/Target-arm-linux/armv7/quadd_d
2.6.20651219-linux-x64/Target-arm-linux/armv8/launcher
2.6.20651219-linux-x64/Target-arm-linux/armv8/libBw64.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libLauncher64.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjection64.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjectionCudaInt64_6_5.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjectionCudaInt64_7_0.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjectionCudaInt64_7_5.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjectionCudaInt64_8_0.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libToolsInjectionProxy64.so
2.6.20651219-linux-x64/Target-arm-linux/armv8/libnvToolsExt.a
2.6.20651219-linux-x64/Target-arm-linux/armv8/quadd_d
2.6.20651219-linux-x64/Target-arm-linux/nvtx/include/nvToolsExt.h
2.6.20651219-linux-x64/Target-arm-linux/quadd_linux_target_diag.py
2.6.20651219-linux-x64/Target-arm/armv7/TegraProfilerTools.apk
2.6.20651219-linux-x64/Target-arm/armv7/injector32
2.6.20651219-linux-x64/Target-arm/armv7/launcher
2.6.20651219-linux-x64/Target-arm/armv7/libLauncher32.so
2.6.20651219-linux-x64/Target-arm/armv7/libToolsInjection32.so
2.6.20651219-linux-x64/Target-arm/armv7/libnvToolsExt.a
2.6.20651219-linux-x64/Target-arm/armv7/quadd_d
2.6.20651219-linux-x64/Target-arm/armv8/TegraProfilerTools.apk
2.6.20651219-linux-x64/Target-arm/armv8/injector64
2.6.20651219-linux-x64/Target-arm/armv8/launcher
2.6.20651219-linux-x64/Target-arm/armv8/libLauncher64.so
2.6.20651219-linux-x64/Target-arm/armv8/libToolsInjection64.so
2.6.20651219-linux-x64/Target-arm/armv8/libnvToolsExt.a
2.6.20651219-linux-x64/Target-arm/armv8/quadd_d
2.6.20651219-linux-x64/Target-arm/nvtx/include/nvToolsExt.h
Archive: /mnt/hgfs/TF/JetPack/jetpack_download/jetpack_docs.zip
creating: content/
creating: content/developertools/
creating: content/developertools/desktop/
creating: content/developertools/desktop/nsight/
creating: content/developertools/desktop/nsight/images/
extracting: content/developertools/desktop/nsight/images/notebox.png
creating: content/developertools/mobile/
creating: content/developertools/mobile/codeworks_android/
inflating: content/developertools/mobile/codeworks_android/codeworks_install.htm
creating: content/developertools/mobile/codeworks_android/images/
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_1_welcome.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_1_welcome.001_600x495.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_3_path.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_3_path.001_600x495.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_5_component_mgr.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_5_component_mgr.001_700x618.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_7_deploy_samples.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_7_deploy_samples.001_600x495.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_8_complete.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_8_complete.001_600x495.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_driver_warning.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_driver_warning.001_500x287.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_incredibuild.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_incredibuild.001_700x283.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_incredibuild_register.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_incredibuild_register.001_700x428.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_license_accept.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_license_accept.001_500x457.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_prev_version_warning.001.png
inflating: content/developertools/mobile/codeworks_android/images/codeworks_install_prev_version_warning.001_450x201.png
creating: content/developertools/mobile/images/
extracting: content/developertools/mobile/images/notebox.png
inflating: content/developertools/mobile/images/nv-perfkit.jpg
extracting: content/developertools/mobile/images/warningbox.png
creating: content/developertools/mobile/jetpack/
creating: content/developertools/mobile/jetpack/images/
inflating: content/developertools/mobile/jetpack/images/jetpack_cuda_fft_ocean_simulation.001.png
inflating: content/developertools/mobile/jetpack/images/jetpack_cuda_fft_ocean_simulation.001_500x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_feedback_particles_sample.001.png
inflating: content/developertools/mobile/jetpack/images/jetpack_feedback_particles_sample.001_700x409.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_begin_target_install.001.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_begin_target_install.001_700x540.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_component_mgr.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_component_mgr.003_700x613.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_device_info.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_device_info.003_700x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_dev_environment.001.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_dev_environment.001_700x540.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_directory.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_directory.003_700x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_force_recovery_mode.001.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_force_recovery_mode.001_600x364.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_install.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_install.003_700x540.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_install_complete.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_install_complete.003_700x540.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_license.002.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_license.002_550x525.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_interface.002.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_interface.002_700x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_layout.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_layout.003_700x540.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_selection.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_network_selection.003_700x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_post_install.003.png
inflating: content/developertools/mobile/jetpack/images/jetpack_l4t_post_install.003_700x527.png
inflating: content/developertools/mobile/jetpack/images/jetpack_tx1_l4t_03_sudo.png
creating: content/developertools/mobile/jetpack/l4t/
creating: content/developertools/mobile/jetpack/l4t/2.2.1/
inflating: content/developertools/mobile/jetpack/l4t/2.2.1/jetpack_l4t_install.htm
inflating: content/developertools/mobile/jetpack/l4t/2.2.1/jetpack_l4t_main.htm
inflating: content/developertools/mobile/jetpack/l4t/2.2.1/jetpack_l4t_release_notes.htm
inflating: content/developertools/mobile/jetpack/l4t/2.2.1/jetpack_l4t_whats_included.htm
creating: content/developertools/mobile/perfhud_es/
creating: content/developertools/mobile/perfhud_es/images/
inflating: content/developertools/mobile/perfhud_es/images/perfhud_fig1_host_connection_interface.001.png
inflating: content/developertools/mobile/perfhud_es/perfhud_introduction.htm
inflating: content/developertools/mobile/perfkit_main.htm
creating: content/developertools/mobile/tegra_graphics_debugger/
creating: content/developertools/mobile/tegra_graphics_debugger/images/
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_android_attach_apk.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_android_attach_apk.001_700x492.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_android_launch_apk.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_android_launch_apk.001_700x482.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_buffers.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_buffers.002_600x516.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_clone_lock.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_fb.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_fb.002_600x517.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_images.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_images.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_linked_shader.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_misc.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_misc.002_600x517.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_pixels.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_pixels.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_pix_ops.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_pix_ops.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_program.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_program.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_program.002_700x602.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_raster.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_raster.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_textures.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_textures.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_transform.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_transform.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_vs.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_vs.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_vtx_spec.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_vtx_spec.002_600x515.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_xfb.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_api_inspector_xfb.002_600x516.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_capture_frame.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_current_target_color.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_current_target_color.002_700x388.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_current_target_depth.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_current_target_depth.002_700x388.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events.002_700x605.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_error_red.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_predefined_filters.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_predefined_filters.001_700x220.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_scrubber.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_scrubber.001_800x115.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_warning_blue.001.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_warning_green.001.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_events_warning_yellow.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_debugger.003.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_debugger.003_800x528.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler.004.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler.004_700x459.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler_bottleneck.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler_bottleneck.001_700x257.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler_summary.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler_summary.001_700x261.png
extracting: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_profiler_toolbar.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_timings.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_frame_timings.002_700x437.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_geometry.004.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_launch_apk.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linked_programs.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linked_programs.002_600x511.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_add_target.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_add_target_ssh.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_attach_app.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_attach_app.002_700x509.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_install_interposer.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_launch_app.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_linux_launch_app.002_700x515.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_perf_dashboard.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_perf_dashboard.001_700x379.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_counters.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_counters.001_700x276.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_primitives.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_primitives.001_700x272.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_shadedpixels.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_shadedpixels.001_700x273.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_shadertype.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_shadertype.001_700x270.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_utilization.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_profiler_utilization.001_700x268.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_blend.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_filter_buttons.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_graphical.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_graphical.002_700x410.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_graphical_predefined_filter.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_histogram.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_histogram.001_700x410.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_histogram_toolbar.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory.002_700x410.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory_hex.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory_hex.001_600x130.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory_int.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_memory_int.001_600x160.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_toolbar.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_resources_view_dropdown.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_save_capture.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_save_capture.001_700x520.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_save_capture_progress.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber.003.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber.003_800x184.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber_add_dialog.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber_hierarchy.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber_mode.001.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber_vertex_shader.002.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_scrubber_vertex_shader.002_800x185.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_shader_editor_view.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_shader_editor_view_compileerrors.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_shader_editor_view_contextmenu.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_shader_editor_view_editing.png
inflating: content/developertools/mobile/tegra_graphics_debugger/images/tgd_view_menu.006.png
inflating: content/developertools/mobile/tegra_graphics_debugger/tegra_graphics_debugger_main.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_api_inspector.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_copyright_notices.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_current_target.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_dynamic_shader_editing.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_event_list.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_frame_debugging.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_frame_profiler.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_frame_scrubber.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_frame_timings.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_geometry.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_install.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_perf_counters.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_perf_dashboard.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_release_notes_l4t.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_resources_view.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_save_capture.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_setup_linux.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_setup_rooted.htm
inflating: content/developertools/mobile/tegra_graphics_debugger/tgd_supported_functions.htm
creating: content/developertools/mobile/tegra_system_profiler/
creating: content/developertools/mobile/tegra_system_profiler/2.6/
inflating: content/developertools/mobile/tegra_system_profiler/2.6/tegraprofiler_release_notes.htm
inflating: content/developertools/mobile/tegra_system_profiler/2.6/tegraprofiler_v2.6.htm
creating: content/developertools/mobile/tegra_system_profiler/2.7/
inflating: content/developertools/mobile/tegra_system_profiler/2.7/tegraprofiler_release_notes_nda.htm
inflating: content/developertools/mobile/tegra_system_profiler/2.7/tegraprofiler_v2.7.htm
creating: content/developertools/mobile/tegra_system_profiler/images/
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_analysissummary.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_analysissummary.001_700x394.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_bottomupview.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_bottomupview.001_700x289.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_symbolresolutionlogs.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_symbolresolutionlogs.001_700x393.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_topdownview.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegraprofiler2x_report_topdownview.001_700x293.png
extracting: content/developertools/mobile/tegra_system_profiler/images/tegrasystemprofiler_function_table_view.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegrasystemprofiler_logo.png
extracting: content/developertools/mobile/tegra_system_profiler/images/tegrasystemprofiler_logo_75x75.png
extracting: content/developertools/mobile/tegra_system_profiler/images/tegrasystemprofiler_report_views.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_about.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_analysis_options.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_analysis_options.001_700x247.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_filter.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_in_progress.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_main.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_main.001_700x466.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_project_package.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_project_package.001_700x538.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_report.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_report.001_700x468.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_timeline_expanded.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_timeline_expanded.001_700x502.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tegra_system_profiler_timeline_scrubber.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_attach_launch_mode.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_attach_only_mode.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_configure_devices.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_cuda_trace_configure.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_cuda_trace_timeline_child_rows.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_cuda_trace_timeline_child_rows.001_700x52.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_cuda_trace_timeline_expanded.001.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_cuda_trace_timeline_expanded.001_700x521.png
inflating: content/developertools/mobile/tegra_system_profiler/images/tsp_manage_connection.001.png
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_cw.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_launch_processes.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_profile_android.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_profile_linux.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_reports.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_sysreq.htm
inflating: content/developertools/mobile/tegra_system_profiler/tegraprofiler_troubleshooting.htm
inflating: content/developertools/mobile/tegra_system_profiler/tsp_broken_backtraces.htm
inflating: content/developertools/mobile/tegra_system_profiler/tsp_cuda_trace.htm
inflating: content/developertools/mobile/tegra_system_profiler/tsp_debug_elf.htm
inflating: content/developertools/mobile/tegra_system_profiler/tsp_nvtx_trace.htm
inflating: content/developertools/mobile_devtools_jetpack_l4t.htm
creating: content/devices/
inflating: content/devices/ardbeg_os_install.htm
creating: content/resources/
creating: content/resources/stylesheets/
inflating: content/resources/stylesheets/run_prettify.js
inflating: content/resources/stylesheets/style.css
inflating: csh.js
creating: Data/
inflating: Data/Alias.js
inflating: Data/Alias.xml
extracting: Data/Breakpoints.js
extracting: Data/Concepts.js
extracting: Data/Filters.js
extracting: Data/Glossary.js
extracting: Data/Glossary_Chunk0.js
inflating: Data/HelpSystem.js
inflating: Data/HelpSystem.xml
inflating: Data/Index.js
inflating: Data/Index_Chunk0.js
inflating: Data/Language.js
inflating: Data/Search.js
inflating: Data/SearchPhrase_Chunk0.js
inflating: Data/SearchPhrase_Chunk1.js
inflating: Data/SearchPhrase_Chunk10.js
inflating: Data/SearchPhrase_Chunk2.js
inflating: Data/SearchPhrase_Chunk3.js
inflating: Data/SearchPhrase_Chunk4.js
inflating: Data/SearchPhrase_Chunk5.js
inflating: Data/SearchPhrase_Chunk6.js
inflating: Data/SearchPhrase_Chunk7.js
inflating: Data/SearchPhrase_Chunk8.js
inflating: Data/SearchPhrase_Chunk9.js
inflating: Data/SearchStem_Chunk0.js
inflating: Data/SearchStem_Chunk1.js
inflating: Data/SearchStem_Chunk2.js
inflating: Data/SearchStem_Chunk3.js
inflating: Data/SearchTopic_Chunk0.js
inflating: Data/SearchUrl_Chunk0.js
inflating: Data/Synonyms.js
inflating: Data/Synonyms.xml
inflating: Data/Toc.js
inflating: Data/Toc_Chunk0.js
inflating: index.html
inflating: index.js
inflating: index.mcwebhelp
inflating: index_CSH.html
inflating: nvidia.ico
creating: Resources/
creating: Resources/Scripts/
inflating: Resources/Scripts/custom.modernizr.js
inflating: Resources/Scripts/foundation.min.js
inflating: Resources/Scripts/jquery.min.js
inflating: Resources/Scripts/jquery.offcanvas.js
inflating: Resources/Scripts/MadCapAll.js
inflating: Resources/Scripts/PIE.htc
inflating: Resources/Scripts/plugins.min.js
extracting: Resources/Scripts/require.config.js
inflating: Resources/Scripts/require.min.js
inflating: Resources/Scripts/stemmer-english.amd.min.js
creating: Skins/
creating: Skins/Default/
creating: Skins/Default/Scripts/
inflating: Skins/Default/Scripts/JetPack.js
creating: Skins/Default/Stylesheets/
creating: Skins/Default/Stylesheets/Components/
creating: Skins/Default/Stylesheets/Components/Images/
extracting: Skins/Default/Stylesheets/Components/Images/collapse.png
extracting: Skins/Default/Stylesheets/Components/Images/edit-profile.png
extracting: Skins/Default/Stylesheets/Components/Images/expand.png
extracting: Skins/Default/Stylesheets/Components/Images/highlight.png
extracting: Skins/Default/Stylesheets/Components/Images/login.png
extracting: Skins/Default/Stylesheets/Components/Images/navigate-next.png
extracting: Skins/Default/Stylesheets/Components/Images/navigate-previous.png
extracting: Skins/Default/Stylesheets/Components/Images/printer.png
extracting: Skins/Default/Stylesheets/Components/Images/select-language.png
extracting: Skins/Default/Stylesheets/Components/Images/select-skin.png
extracting: Skins/Default/Stylesheets/Components/Images/star-empty.png
extracting: Skins/Default/Stylesheets/Components/Images/star-full.png
inflating: Skins/Default/Stylesheets/Components/Mobile.css
inflating: Skins/Default/Stylesheets/Components/Styles.css
inflating: Skins/Default/Stylesheets/Components/Tablet.css
creating: Skins/Default/Stylesheets/Images/
extracting: Skins/Default/Stylesheets/Images/book-open.png
extracting: Skins/Default/Stylesheets/Images/book.png
extracting: Skins/Default/Stylesheets/Images/browseActive.png
extracting: Skins/Default/Stylesheets/Images/browseInactive.png
extracting: Skins/Default/Stylesheets/Images/close.png
extracting: Skins/Default/Stylesheets/Images/collapse.png
extracting: Skins/Default/Stylesheets/Images/communityActive.png
extracting: Skins/Default/Stylesheets/Images/communityInactive.png
extracting: Skins/Default/Stylesheets/Images/diagonal_lines.png
extracting: Skins/Default/Stylesheets/Images/edit-profile.png
extracting: Skins/Default/Stylesheets/Images/expand.png
inflating: Skins/Default/Stylesheets/Images/Filter.png
extracting: Skins/Default/Stylesheets/Images/FilterOutline.png
extracting: Skins/Default/Stylesheets/Images/glossaryActive.png
extracting: Skins/Default/Stylesheets/Images/glossaryInactive.png
extracting: Skins/Default/Stylesheets/Images/help-control.png
extracting: Skins/Default/Stylesheets/Images/highlight.png
extracting: Skins/Default/Stylesheets/Images/index-collapsed.png
extracting: Skins/Default/Stylesheets/Images/index-expanded.png
extracting: Skins/Default/Stylesheets/Images/index.png
extracting: Skins/Default/Stylesheets/Images/indexActive.png
extracting: Skins/Default/Stylesheets/Images/indexInactive.png
inflating: Skins/Default/Stylesheets/Images/loading-32px.gif
inflating: Skins/Default/Stylesheets/Images/loading.gif
extracting: Skins/Default/Stylesheets/Images/login-dialog-icon.png
extracting: Skins/Default/Stylesheets/Images/login.png
inflating: Skins/Default/Stylesheets/Images/logo.png
extracting: Skins/Default/Stylesheets/Images/magnifying_glass.png
inflating: Skins/Default/Stylesheets/Images/MCSlider_controls.png
inflating: Skins/Default/Stylesheets/Images/MCSlider_loader.gif
extracting: Skins/Default/Stylesheets/Images/navigate-next.png
extracting: Skins/Default/Stylesheets/Images/navigate-previous.png
extracting: Skins/Default/Stylesheets/Images/new-indicator.png
extracting: Skins/Default/Stylesheets/Images/nvidia-logo-header.png
extracting: Skins/Default/Stylesheets/Images/printer.png
extracting: Skins/Default/Stylesheets/Images/RatingStars.png
inflating: Skins/Default/Stylesheets/Images/SearchIcon.png
extracting: Skins/Default/Stylesheets/Images/select-language.png
extracting: Skins/Default/Stylesheets/Images/select-skin.png
extracting: Skins/Default/Stylesheets/Images/star-empty.png
extracting: Skins/Default/Stylesheets/Images/star-full.png
extracting: Skins/Default/Stylesheets/Images/tocActive.png
extracting: Skins/Default/Stylesheets/Images/tocInactive.png
extracting: Skins/Default/Stylesheets/Images/topic.png
inflating: Skins/Default/Stylesheets/Images/transparent.gif
inflating: Skins/Default/Stylesheets/Slideshow.css
inflating: Skins/Default/Stylesheets/Styles.css
inflating: Skins/Default/Stylesheets/TextEffects.css
inflating: Skins/Default/Stylesheets/Topic.css
Version: 7.0
DashedVersion: 7-0
1
/mnt/hgfs/TF/JetPack//_installer/run_command -c=“dpkg -i --force-overwrite /mnt/hgfs/TF/JetPack/jetpack_download/cuda-repo-ubuntu1404-7-0-local_7.0-76_amd64.deb;apt-get update; apt-get -y --force-yes install cuda-toolkit-7-0;” -d=/mnt/hgfs/TF/JetPack//_installer/tmp -l=/mnt/hgfs/TF/JetPack/_installer/logs//cuda_host_tx1.log
dpkg-query: package ‘cuda-toolkit-7-0’ is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
0
