I managed to get around the problem with installing qemu (meaning I am using 7.23 instead of 7.11 which wasn’t available), but I now get the following error:
15:38:27 INFO : File System and OS : sudo ./apply_binaries.sh
15:38:27 INFO : File System and OS : sudo mkdir -p rootfs/opt/nvidia/deb_repos
15:38:27 INFO : File System and OS : **********************
15:38:27 INFO : File System and OS : exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh
15:40:51 ERROR : File System and OS : sudo: ./apply_binaries.sh: command not found
15:40:51 INFO : File System and OS : exit status 1
15:40:51 INFO : File System and OS : [ Package Install Finished with Error ]
15:40:51 INFO : File System and OS : [ 3.49 GB used. Disk Avail: 12.91 GB ]
15:40:51 INFO : File System and OS : [ NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP Install took 2m25s ]
15:40:51 ERROR : File System and OS : Run commands failed at step Install: command /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh finished with error
15:40:51 ERROR : File System and OS : command terminated with error
15:40:51 ERROR : File System and OS : install ‘File System and OS’ failure
Thanks in advance for all help.
UPDATE: tried again, now it’s working for some reason.
