You’re probably referring to the drivers used in the desktop PCs…they are all a different architecture and do not work on Jetsons. Are you looking for a particular feature or problem solution?
Desktop drivers don’t work on Jetsons. The L4T flash installs those drivers. Jetson GPUs are wired directly to the memory controller, thus PCI based drivers cannot function.
