Installation of nvidia-peermem for multi-node GPUDirect RDMA
We are currently trying to install the nvidia-peermem module to enable GPUDirect RDMA on multiple nodes connected via Infiniband. Does it require the MLNX_OFED driver like nv_peer_memory? According to your documentation, it should also work with the inbox drivers on the supported distribution packages, and supported by Mellanox ConnectX-3 or newer adapters. Our system has Mellanox Connect-X6 adapter, but we do not have MLNX_OFED installed since we are using inbox drivers. Can we still install nvidia_peermem in that case?
