I tried installing TADP 3.0r4. On Windows 7 I got the error message similar to a previous post https://devtalk.nvidia.com/default/topic/811800/android-development/tadp-installation-failure-in-both-win7-and-win8/.
I’m more interested in the TADP version for Linux 64bit since it has CUDA. On Ubuntu 12.04 64bit when I install it, I got an error saying that the file /.NVIDIA/TADP/007/android-ndk-r10c-linux-x86_64.bin is not found.
I checked that location and the file is actually there, with execution permission. However when I manually try to run it in a terminal it still says found is not found. After doing some google search I found this post explaining the issue:
http://askubuntu.com/questions/133389/no-such-file-or-directory-but-the-file-exists/133460#133460
Basically it says that running a 32-bit binary on a 64bit platform will fail.
I tried what the post said to verify the property of the file by using the “file” command. It shows the following:
$ file android-ndk-r10c-linux-x86_64.bin
android-ndk-r10c-linux-x86_64.bin: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=0x13b76de68ec17f30e2e19d37f8b379fc204107af, stripped
So it seems that the file is indeed a 32bit executable. Is this the issue and how do I resolve this?
