As part of tensorflow installation on the jetson nano as given in the link Installing TensorFlow for Jetson Platform - NVIDIA Docs
I ran the following command
sudo pip3 install -U testresources setuptools==65.5.0
It is throwing the error as
ERROR: No matching distribution found for setuptools==65.5.0
The detailed error is pasted below. Let me know what could be the problem and how it can be rectified
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with ‘-m pip’ instead of running pip directly.
WARNING: The directory ‘/home/mistral/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo’s -H flag.
Collecting testresources
Downloading testresources-2.0.1-py2.py3-none-any.whl (36 kB)
ERROR: Could not find a version that satisfies the requirement setuptools==65.5.0 (from versions: 0.6b1, 0.6b2, 0.6b3, 0.6b4, 0.6rc1, 0.6rc2, 0.6rc3, 0.6rc4, 0.6rc5, 0.6rc6, 0.6rc7, 0.6rc8, 0.6rc9, 0.6rc10, 0.6rc11, 0.7.2, 0.7.3, 0.7.4, 0.7.5, 0.7.6, 0.7.7, 0.7.8, 0.8, 0.9, 0.9.1, 0.9.2, 0.9.3, 0.9.4, 0.9.5, 0.9.6, 0.9.7, 0.9.8, 1.0, 1.1, 1.1.1, 1.1.2, 1.1.3, 1.1.4, 1.1.5, 1.1.6, 1.1.7, 1.2, 1.3, 1.3.1, 1.3.2, 1.4, 1.4.1, 1.4.2, 2.0, 2.0.1, 2.0.2, 2.1, 2.1.1, 2.1.2, 2.2, 3.0, 3.0.1, 3.0.2, 3.1, 3.2, 3.3, 3.4, 3.4.1, 3.4.2, 3.4.3, 3.4.4, 3.5, 3.5.1, 3.5.2, 3.6, 3.7, 3.7.1, 3.8, 3.8.1, 4.0, 4.0.1, 5.0, 5.0.1, 5.0.2, 5.1, 5.2, 5.3, 5.4, 5.4.1, 5.4.2, 5.5, 5.5.1, 5.6, 5.7, 5.8, 6.0.1, 6.0.2, 6.1, 7.0, 8.0, 8.0.1, 8.0.2, 8.0.3, 8.0.4, 8.1, 8.2, 8.2.1, 8.3, 9.0, 9.0.1, 9.1, 10.0, 10.0.1, 10.1, 10.2, 10.2.1, 11.0, 11.1, 11.2, 11.3, 11.3.1, 12.0, 12.0.1, 12.0.2, 12.0.3, 12.0.4, 12.0.5, 12.1, 12.2, 12.3, 12.4, 13.0.1, 13.0.2, 14.0, 14.1, 14.1.1, 14.2, 14.3, 14.3.1, 15.0, 15.1, 15.2, 16.0, 17.0, 17.1, 17.1.1, 18.0, 18.0.1, 18.1, 18.2, 18.3, 18.3.1, 18.3.2, 18.4, 18.5, 18.6, 18.6.1, 18.7, 18.7.1, 18.8, 18.8.1, 19.0, 19.1, 19.1.1, 19.2, 19.3, 19.4, 19.4.1, 19.5, 19.6, 19.6.1, 19.6.2, 19.7, 20.0, 20.1, 20.1.1, 20.2.2, 20.3, 20.3.1, 20.4, 20.6.6, 20.6.7, 20.6.8, 20.7.0, 20.8.0, 20.8.1, 20.9.0, 20.10.1, 21.0.0, 21.1.0, 21.2.0, 21.2.1, 21.2.2, 22.0.0, 22.0.1, 22.0.2, 22.0.4, 22.0.5, 23.0.0, 23.1.0, 23.2.0, 23.2.1, 24.0.0, 24.0.1, 24.0.2, 24.0.3, 24.1.0, 24.1.1, 24.2.0, 24.2.1, 24.3.0, 24.3.1, 25.0.0, 25.0.1, 25.0.2, 25.1.0, 25.1.1, 25.1.2, 25.1.3, 25.1.4, 25.1.5, 25.1.6, 25.2.0, 25.3.0, 25.4.0, 26.0.0, 26.1.0, 26.1.1, 27.0.0, 27.1.0, 27.1.2, 27.2.0, 27.3.0, 27.3.1, 28.0.0, 28.1.0, 28.2.0, 28.3.0, 28.4.0, 28.5.0, 28.6.0, 28.6.1, 28.7.0, 28.7.1, 28.8.0, 28.8.1, 29.0.0, 29.0.1, 30.0.0, 30.1.0, 30.2.0, 30.2.1, 30.3.0, 30.4.0, 31.0.0, 31.0.1, 32.0.0, 32.1.0, 32.1.1, 32.1.2, 32.1.3, 32.2.0, 32.3.0, 32.3.1, 33.1.0, 33.1.1, 34.0.0, 34.0.1, 34.0.2, 34.0.3, 34.1.0, 34.1.1, 34.2.0, 34.3.0, 34.3.1, 34.3.2, 34.3.3, 34.4.0, 34.4.1, 35.0.0, 35.0.1, 35.0.2, 36.0.1, 36.1.0, 36.1.1, 36.2.0, 36.2.1, 36.2.2, 36.2.3, 36.2.4, 36.2.5, 36.2.6, 36.2.7, 36.3.0, 36.4.0, 36.5.0, 36.6.0, 36.6.1, 36.7.0, 36.7.1, 36.7.2, 36.8.0, 37.0.0, 38.0.0, 38.1.0, 38.2.0, 38.2.1, 38.2.3, 38.2.4, 38.2.5, 38.3.0, 38.4.0, 38.4.1, 38.5.0, 38.5.1, 38.5.2, 38.6.0, 38.6.1, 38.7.0, 39.0.0, 39.0.1, 39.1.0, 39.2.0, 40.0.0, 40.1.0, 40.1.1, 40.2.0, 40.3.0, 40.4.0, 40.4.1, 40.4.2, 40.4.3, 40.5.0, 40.6.0, 40.6.1, 40.6.2, 40.6.3, 40.7.0, 40.7.1, 40.7.2, 40.7.3, 40.8.0, 40.9.0, 41.0.0, 41.0.1, 41.1.0, 41.2.0, 41.3.0, 41.4.0, 41.5.0, 41.5.1, 41.6.0, 42.0.0, 42.0.1, 42.0.2, 43.0.0, 44.0.0, 44.1.0, 44.1.1, 45.0.0, 45.1.0, 45.2.0, 45.3.0, 46.0.0, 46.1.0, 46.1.1, 46.1.2, 46.1.3, 46.2.0, 46.3.0, 46.3.1, 46.4.0, 47.0.0, 47.1.0, 47.1.1, 47.2.0, 47.3.0, 47.3.1, 47.3.2, 48.0.0, 49.0.0, 49.0.1, 49.1.0, 49.1.1, 49.1.2, 49.1.3, 49.2.0, 49.2.1, 49.3.0, 49.3.1, 49.3.2, 49.4.0, 49.5.0, 49.6.0, 50.0.0, 50.0.1, 50.0.2, 50.0.3, 50.1.0, 50.2.0, 50.3.0, 50.3.1, 50.3.2, 51.0.0, 51.1.0, 51.1.0.post20201221, 51.1.1, 51.1.2, 51.2.0, 51.3.0, 51.3.1, 51.3.2, 51.3.3, 52.0.0, 53.0.0, 53.1.0, 54.0.0, 54.1.0, 54.1.1, 54.1.2, 54.1.3, 54.2.0, 56.0.0, 56.1.0, 56.2.0, 57.0.0, 57.1.0, 57.2.0, 57.3.0, 57.4.0, 57.5.0, 58.0.0, 58.0.1, 58.0.2, 58.0.3, 58.0.4, 58.1.0, 58.2.0, 58.3.0, 58.4.0, 58.5.0, 58.5.1, 58.5.2, 58.5.3, 59.0.1, 59.1.0, 59.1.1, 59.2.0, 59.3.0, 59.4.0, 59.5.0, 59.6.0)
