I have a Jetson TX1 with Sample file 23.2 on it. It has the associated OpenCV4tegra as well. It also carries CUDA 7.0. While I try to install zed-ros-wrapper, it throws the error:
CMake Error at /usr/share/OpenCV/OpenCVConfig.cmake:251 (if):
if given arguments:
"VERSION_LESS" "5.5"
Unknown arguments specified
Call Stack (most recent call first):
zed-ros-wrapper/CMakeLists.txt:32 (find_package)
-- Configuring incomplete, errors occurred!
I tried editing the files, but am not sure if I did it right. I believe an alternative option would be to install a different version of OpenCV. If so, are there any that are compatible with Jetson TX1?
