Question A: What linux version are you installing in? Most local changes
are in localrc in $PGI/linux86-64/6.0/bin.
If you run into any more problems, send the following to trs@pgroup.com
the output of
gcc -v hello.c
output of gcc -m32 -v hello.c
cat /etc/issue
/lib/libc.so.6
the files /usr/include/sys/types.h
/usr/include/bits/types.h
output from pgcc -dryrun hello.c
Question B:
The only difference between the workstation and server products
is the license. Workstation is single user, node-locked, 1 process,
4 threads per process, in its code generation and tool support.
Server License is multi-user (at a time), floating, 1 process, 16 threads
per process.
