localhost scripts]$ ./install_dependencies.sh This is a helper script for installing dependencies to build the Isaac SDK.
First argument is the optional CUDA version. By default CUDA 10.2 dependent
packages are installed. GPUs with Maxwell, Pascal, Volta and Turing
architectures are supported in this configuration. Experimental support of
newer architecture GPUs is available with the --config=x86_64_cuda_11_1
option.
CUDA 10.2 support was selected (default option).
[sudo] password for NVIDIA:
sudo: apt-get: command not found
[INFO] Installing packages - ffmpeg
[ERROR] Failed to install packages - ffmpeg
Facing that apt-get in centos
also tried for yum install
still not working
