I am sorry I have dummy question. I am just starting to use AODT.
so I run on Dell workstation 7920T with 3 GPUs of Nvidia Quadro RTX8000 on Linux 20.04 desktop
I try to install the Digital twin by following the documentations:
https://docs.nvidia.com/aerial/aerial-dt/text/user_guide.html#installation
I obtain the NGC key from Dashboard | NVIDIA NGC , through “Keys/Secrets” → “Generate API Key”
However, I could not unzip the aodt_bundle.zip
with output from terminal
~$ curl -L "https://api.ngc.nvidia.com/v2/org/esee5uzbruax/resources/aodt-installer/versions/$versionTag/files/aodt_bundle.zip" -H "Authorization: Bearer$TOKEN" -H "Content-Type: application/json" -o $downloadedZip
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 118 100 118 0 0 287 0 --:--:-- --:--:-- --:--:-- 287
It seems like the file is very small (118bytes). and when I do unzip:
~$ unzip -o $downloadedZip
Archive: /home/nvadmin/aodt_bundle.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /home/nvadmin/aodt_bundle.zip or
/home/nvadmin/aodt_bundle.zip.zip, and cannot find /home/nvadmin/aodt_bundle.zip.ZIP, period.
From here, Did I already miss something .? or is it just simply because it does not work on Ubuntu 20.04 desktop, or any specific reason?
Thank you.
