I installed JetPack SDK v5.0.2 using SDK Manager v1.8.4.
But, the following directory was created in Jetson device.
- /usr/local/cuda-11.4
- /usr/local/cuda-11.7
I read the following release notes.
https://docs.nvidia.com/jetson/archives/jetpack-archived/jetpack-502/release-notes/index.html#libraries-apis
2.2. Libraries and APIs
CUDA 11.4.14
Is this the intended configuration?
The full CUDA libraries are installed in the cuda-11.4
folder.
The cuda-11.7
folder only contains compute-sanitizer.
@AastaLLL Thank you for your comment.
I think that I need to set up a cuda-11.7
path to use compute-sanitizer.
Is my understanding correct? Because, the cuda-11.4
path is set by default.
I think that it is better not to set the cuda-11.4
and cuda-11.7
paths at the same time.
compute-sanitizer is available in both cuda-11.4 and cuda-11.7.
Let me get more information from our internal team first.
system
Closed
#7
