Hello folks!
I might be missing something, but I’m trying to compile OpenCV following the guidelines from the http://elinux.org/Jetson/Installing_OpenCV. However I’m getting the following error.
[ 75%] Building CXX object apps/traincascade/CMakeFiles/opencv_traincascade.dir/imagestorage.cpp.o
Linking CXX executable ../../bin/opencv_traincascade
[ 75%] Built target opencv_traincascade
make[1]: *** [modules/gpu/CMakeFiles/opencv_gpu.dir/all] Error 2
make: *** [all] Error 2
ubuntu@tegra-ubuntu:~/opencv-2.4.9/build$
In both L4T 21.1 and L4T 21.2 I’m getting the same error. However in L4T 21.2 the error appears around at 85%. I’m compiling the library because I’m using some libraries that are not prebuilt version.
Any help will be highly appreciated.
Thank you beforehand folks!
