I am helping a friend program their their Jetson AGX; I was able to flash the jetson without a problem but after the jetson restarts and I continue with installing components and receive error messages in the logs I am having a hard time deciphering what is being implied. I was hoping someone could help me understand what is happening by look at the logs. Thanks in advance!
07:53:33 SUMMARY: Device Mode Host Setup in Target SDK: Install completed successfully.
07:53:33 SUMMARY: DateTime Target Setup: Install completed successfully.
07:53:33 DEBUG: running command < true >
07:53:33 INFO: command finished successfully
07:53:33 DEBUG: CUDA Toolkit for L4T: using adapter to install NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to
07:53:33 INFO: CUDA Toolkit for L4T: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no stephen@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
07:53:33 INFO: CUDA Toolkit for L4T: [ Package Install Started ]
07:53:33 INFO: CUDA Toolkit for L4T: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb Package | tr -d ‘\n’
07:53:33 INFO: CUDA Toolkit for L4T: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb Version | tr -d ‘\n’
07:53:33 INFO: CUDA Toolkit for L4T: **********************
07:53:33 ERROR: CUDA Toolkit for L4T: lost connection
07:53:33 ERROR: CUDA Toolkit for L4T: command terminated with error
07:53:33 SUMMARY: VPI on Target: Depends on failed component
07:53:33 DEBUG: OpenCV on Target: using adapter to install NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to
07:53:33 INFO: OpenCV on Target: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no stephen@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
07:53:34 INFO: OpenCV on Target: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP include 5 package
07:53:34 INFO: OpenCV on Target: exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh stephen@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no stephen@192.168.55.1 “set -o pipefail; ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh | sed ‘s/^/SDKM_INSTALL_ERROR /’ && rm -f ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh”
07:53:34 ERROR: OpenCV on Target: lost connection
07:53:34 INFO: OpenCV on Target: [ Package PreInstall Finished with Error ]
07:53:34 ERROR: OpenCV on Target: command terminated with error
07:53:34 SUMMARY: VPI on Target: Depends on failed component
07:53:34 DEBUG: running command < true >
07:53:34 INFO: command finished successfully
07:53:34 DEBUG: cuDNN on Target: using adapter to install NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to
07:53:34 INFO: cuDNN on Target: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no stephen@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
07:53:34 INFO: cuDNN on Target: [ Package Install Started ]
07:53:34 INFO: cuDNN on Target: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb Package | tr -d ‘\n’
07:53:34 INFO: cuDNN on Target: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb Version | tr -d ‘\n’
07:53:34 INFO: cuDNN on Target: infer package info from file name libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb [ name: libcudnn8, version: 8.0.0.180-1+cuda10.2 ]
07:53:34 INFO: cuDNN on Target: **********************
07:53:34 ERROR: cuDNN on Target: lost connection
07:53:34 INFO: cuDNN on Target: [ Package Install Finished with Error ]
07:53:34 ERROR: cuDNN on Target: command terminated with error
07:53:34 SUMMARY: Multimedia API: Depends on failed component
07:53:34 DEBUG: NVIDIA Nsight Systems: using adapter to install NV_L4T_NVIDIA_NSIGHT_SYSTEMS_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER to
07:53:35 INFO: NVIDIA Nsight Systems: exec_command: ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no stephen@192.168.55.1 “df -B1 / | tail -1 | awk ‘{ printf $4 }’”
07:53:35 INFO: NVIDIA Nsight Systems: [ Package Install Started ]
07:53:35 INFO: NVIDIA Nsight Systems: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/nsight-systems-cli-2020.5.3_2020.5.3.17-1_arm64.deb Package | tr -d ‘\n’
07:53:35 INFO: NVIDIA Nsight Systems: exec_command: dpkg -f /home/shep/Downloads/nvidia/sdkm_downloads/nsight-systems-cli-2020.5.3_2020.5.3.17-1_arm64.deb Version | tr -d ‘\n’
07:53:35 INFO: NVIDIA Nsight Systems: infer package info from file name nsight-systems-cli-2020.5.3_2020.5.3.17-1_arm64.deb [ name: nsight-systems-cli-2020.5.3, version: 2020.5.3.17-1 ]
07:53:35 INFO: NVIDIA Nsight Systems: **********************
07:53:35 ERROR: NVIDIA Nsight Systems: lost connection
07:53:35 INFO: NVIDIA Nsight Systems: [ Package Install Finished with Error ]
07:53:35 ERROR: NVIDIA Nsight Systems: command terminated with error
07:53:35 SUMMARY: NVIDIA Nsight Systems: Failed to install debian package [target]
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2021, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
