Installing Cuda 3.0 tools on new Macbook pro (GT330M)
As anybody had any luck installing the Cuda 3.0 tools on the new macbook pro with GT330M graphic card?
On my previous macbook pro with 9400/9600M, after installation, I would also see the driver info in the system preference in the “other” section.
By default the Intel is used and automatically switched to GT330M when needed. I reinstalled after having enabled GT300M fulltime … without much luck.
It seems that the installer does not detect the GT330M properly and therefore does not install the drivers properly.
Any other MAC guys around with similar problems?
Eric
Same problem here. Running deviceQuery gave :
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
There is no device supporting CUDA
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 53931, CUDA Runtime Version = 0.0, NumDevs = 0
PASSED
wait, I did manage to install the driver.
I can see the CUDA icon in ‘other’ section, and it says:
CUDA driver version: 3.0.14
GPU driver version: 1.6.10.34(19.5.2f18)
How did you install the driver?
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
FAILED
The directions say:
Install the CUDA Driver by installing the appropriate CUDA driver package based on the GPU in the system (either NVIDIA GeForce GPU or NVIDIA Quadro GPU).
But they don’t say where you get the driver or how to install it.
After installing the CUDA driver, everything went fine.
Here are some results for those interested, from deviceQuery and bandwidthTest
% ./deviceQuery
There is 1 device supporting CUDA
Device 0: “GeForce GT 330M”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 2
Total amount of global memory: 536543232 bytes
Number of multiprocessors: 6
Number of cores: 48
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.10 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 53931, CUDA Runtime Version = 3.0, NumDevs = 1, Device = GeForce GT 330M
PASSED
% ./bandwidthTest --memory=pinned
[bandwidthTest]
./bandwidthTest Starting…
Running on…
Device 0: GeForce GT 330M
Quick Mode
Host to Device Bandwidth, 1 Device(s), Pinned memory, Write-Combined Memory Enabled
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 2640.5
Device to Host Bandwidth, 1 Device(s), Pinned memory, Write-Combined Memory Enabled
33554432 3206.5
Device to Device Bandwidth, 1 Device(s)
33554432 8534.0
[bandwidthTest] - Test results:
PASSED
How do you install the CUDA driver?
I installed the cudatoolkit_3.0_macos_32.pkg.
/Chris
Thanks,
/Chris
FYI: I had the exact same problems as above and it didn’t resolve itself until the machine was rebooted.
Thanks. I tried rebooting, but I’ll try it again.
/Chris
No dice. I still get:
FAILED
Just to be clear, all I should have to do is install the cudatoolkit_3.0_macos_32.pkg and then the gpucomputingsdk_3.0_macros_32.pkg and run the make file?
Thanks,
/Chris
did you install the driver ?
First entry in the table of MacOS download:
Developer Drivers for MacOS
http://developer.nvidia.com/object/cuda_3_0_downloads.html
Luc
Dear,
MacBook Pro 6.2 2.66Ghz Intel Core i7, MacOSX: 10.6.4,
NVIDIA GeForce GT 330M, Memory: 8GB 1067 MHz DDR3
“dmesg” command shows,
npvhash=4095
PAE enabled
64 bit mode enabled
Darwin Kernel Version 10.4.0: Fri Apr 23 18:28:53 PDT 2010; root:xnu-1504.7.4~1/RELEASE_I386
vm_page_bootstrap: 1989319 free pages and 107833 wired pages
  1. I installed cudadriver_3.0.14_macos.dmg
  2. Reboot.
  3. In CUDA Preferences, dialog shows
    • CUDA Driver version: 3.0.14
    • GPU Driver Version: 1.6.16.11 (19.5.8f01)
  4. Next, installed cudatoolkit_3.0_macos_32.pkg
  5. Next, installed gpucomputingsdk_3.0_macox_32.pkg
  6. run make command
  7. The messages of “deviceQuery” command show
deviceQuery, CUDA Driver=CUDART, CUDA Driver Version=55683, CUDA Runtime Version=0.0 NumDevs=0
PASSED
Any comment would be appreciated ~
Best Regards,
kcjin000@hotmail.com
Dear,
npvhash=4095
PAE enabled
64 bit mode enabled
  2. Reboot.
  6. run make command
PASSED
Best Regards,
I had all the same issued above with CUDA 3.1 on my i7 MBP with the GT330M.
Apparently you have to force the use of the nvidia drivers after they’re installed. This handy tool [url=“gfxCardStatus by cody krieger”]http://codykrieger.com/gfxCardStatus/[/url] allows you to do just that. Forcing the nvidia card to be used (not intel or dynamic switching) had deviceQuery showing the right device and had my CUDA programs running again. Hope this works for you too.
Thanks @oldmanjank! This really helped me out for my MBP 2010 i5.
I had exactly the same error message you described above:
./deviceQuery Starting...
PASSED
Press <Enter> to Quit...
Then I installed gfxCardStatus, switched to “NVIDIA only” mode, reinstalled the driver and surprise surprise I’m getting this:
Device 0: "GeForce GT 330M"
  CUDA Driver Version:						   3.10
  Total amount of global memory:				 268107776 bytes
  Number of cores:							   48
  Warp size:									 32
  Integrated:									No
PASSED
Good software!
PASSED
  Number of cores:							   48
  Warp size:									 32
  Integrated:									No
PASSED
Good software!
