Installing cudart (and more) in Yocto.
I’ve created a rootfs for Jetson using Yocto, using the recipes from https://github.com/kraj/meta-jetson-tk1. This layer has a recipe that gives me libcuda.so, but I’m missing libcudart.so and possibly other libs/headers.
Are more cuda stuff available for download somewhere? I installed the JetPack, and inside I found debs for what I need, e.g. cuda-cudart-6-5_6.5-50_armhf.deb and cuda-cudart-dev-6-5_6.5-50_armhf.deb.
I should be able to work with these to add what I need to my image, but
  1. Am I allowed to do so?
  2. Can I get these files in a format that fits better, a source/binary package?
Gave this a go today, but did not make it work. The “NVIDIA Cuda Getting Started Guide for Linux” has instructions for misc distros, but none for installing/running on a system such as Yocto/Angstrom. Have anyone done this successfully, or can anyone tell me what components are needed?
What do I need to have in place on my embedded system besides a working kernel and libcuda.so to make this work?
Figured this out. The problem was that the ldconfig was not setup correctly.
deviceQuery gave the following output before:
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
Fixed it with these commands:
Result = FAIL
echo "include /etc/ld.so.conf.d/nvidia-tegra.conf" > /etc/ld.so.conf
echo "/usr/lib/arm-linux-gnueabihf/tegra" > /etc/ld.so.conf.d/nvidia-tegra.conf
ldconfig
Now deviceQuery works.
