Machine 2 • GV100GL [Tesla V100 PCIe 16GB] • DeepStream SDK 5.0 •JetPack Version (valid for Jetson only) • 5.1.5.0-1+cuda10.0 (Inside Docker) • Driver Version 435.21
I have two devices as listed above where I would like to install Deepstream for inference on a model trained by Transfer Learning Toolkit. As per the documentation both of my devices are not listed. Is there any way I can use Deepstream on either of the machines mentioned above?
Hi
We maintain and test deepstreamSDK on Tesla series cards and Jetson devices, DRIVE AGX should be with QNX os as I know, and should be not supported, and for V100, you could download the package and give a try.
You may change sink type to 1 Fakesink or 3 File or 4 RTSPStreaming in config.
another option, V100 is compute card, you may follow this https://elinux.org/Deepstream/FAQ 5A to setup virtual display, the FAQ is for T4 or P4, but you may give a try.
