Yesterday I’ve got new Jetson TK1 kit, upgraded OS to Ubuntu 16.04 with ‘do-release-upgrade’ and then tried to install docker.
The software itself installs, however dockerd fails to start with the following message:
INFO[2017-10-13T06:43:52.715057770Z] libcontainerd: new containerd process, pid: 19233
WARN[0000] containerd: low RLIMIT_NOFILE changing to max current=1024 max=1048576
WARN[2017-10-13T06:43:53.774347773Z] unable to modify root key limit, number of containers could be limited by this quota: open /proc/sys/kernel/keys/root_maxkeys: no such file or directory
ERRO[2017-10-13T06:43:53.956491628Z] [graphdriver] prior storage driver devicemapper failed: devicemapper: Error running deviceCreate (CreatePool) dm_task_run failed
Error starting daemon: error initializing graphdriver: devicemapper: Error running deviceCreate (CreatePool) dm_task_run failed
Has anyone been able to successfully install Docker on TK1 running Ubuntu 16.04 ?
do-release-upgrade breaks the install. Check “sha1sum -c /etc/nv_tegra_release”…the NVIDIA-specific hardware files are probably no longer correct.
I suspect that the root key limit itself is part of the kernel CONFIG_QUOTA and/or CONFIG_QUOTACTL, but it won’t matter if that sha1sum fails.
I ran ‘sha1sum -c /etc/nv_tegra_release’ and I’ve got ‘OK’ for all libraries.
However, if ‘do-release-upgrade’ breaks the install, is there any other way to updgrade bump Ubuntu to 16.04 ?
One more thing though: I ran check-config (Docker tool to check whether system is Docker-ready), and here’s what I’ve got:
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: <b>missing</b>
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: <b>missing</b>
- CONFIG_MEMCG: <b>missing</b>
- CONFIG_KEYS: <b>missing</b>
- CONFIG_VETH: <b>missing</b>
- CONFIG_BRIDGE: <b>missing</b>
- CONFIG_BRIDGE_NETFILTER: missing
- CONFIG_NF_NAT_IPV4: enabled
- CONFIG_IP_NF_FILTER: enabled
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: <b>missing</b>
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled
- CONFIG_NETFILTER_XT_MATCH_IPVS: <b>missing</b>
- CONFIG_IP_NF_NAT: <b>missing</b>
- CONFIG_NF_NAT: enabled
- CONFIG_NF_NAT_NEEDED: enabled
- CONFIG_POSIX_MQUEUE: <b>missing</b>
- CONFIG_DEVPTS_MULTIPLE_INSTANCES: enabled
Optional Features:
- CONFIG_USER_NS: missing
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: missing
- CONFIG_MEMCG_SWAP: missing
- CONFIG_MEMCG_SWAP_ENABLED: missing
- CONFIG_MEMCG_KMEM: missing
- CONFIG_RESOURCE_COUNTERS: enabled
- CONFIG_BLK_CGROUP: missing
- CONFIG_BLK_DEV_THROTTLING: missing
- CONFIG_IOSCHED_CFQ: missing
- CONFIG_CFQ_GROUP_IOSCHED: missing
- CONFIG_CGROUP_PERF: missing
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: missing
- CONFIG_NETPRIO_CGROUP: missing
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_VS: missing
- CONFIG_IP_VS_NFCT: missing
- CONFIG_IP_VS_RR: missing
- CONFIG_EXT3_FS: missing
- CONFIG_EXT3_FS_XATTR: missing
- CONFIG_EXT3_FS_POSIX_ACL: missing
- CONFIG_EXT3_FS_SECURITY: missing
(enable these ext3 configs if you are using ext3 as backing filesystem)
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: missing
enable these ext4 configs if you are using ext4 as backing filesystem
- Network Drivers:
- "overlay":
- CONFIG_VXLAN: missing
Optional (for encrypted networks):
- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: missing
- CONFIG_CRYPTO_SEQIV: missing
- CONFIG_CRYPTO_GHASH: missing
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: missing
- CONFIG_XFRM_ALGO: enabled
- CONFIG_INET_ESP: enabled
- CONFIG_INET_XFRM_MODE_TRANSPORT: enabled
- "ipvlan":
- CONFIG_IPVLAN: missing
- "macvlan":
- CONFIG_MACVLAN: missing
- CONFIG_DUMMY: enabled
- "ftp,tftp client in container":
- CONFIG_NF_NAT_FTP: enabled
- CONFIG_NF_CONNTRACK_FTP: enabled
- CONFIG_NF_NAT_TFTP: enabled
- CONFIG_NF_CONNTRACK_TFTP: enabled
- Storage Drivers:
- "aufs":
- CONFIG_AUFS_FS: missing
- "btrfs":
- CONFIG_BTRFS_FS: missing
- CONFIG_BTRFS_FS_POSIX_ACL: missing
- "devicemapper":
- CONFIG_BLK_DEV_DM: enabled (as module)
- CONFIG_DM_THIN_PROVISIONING: missing
- "overlay":
- CONFIG_OVERLAY_FS: missing
- "zfs":
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
There’s quite a few ‘missing’ in the ‘Generally Necessary’ section.
Does anyone know if I need to recompile kernel with all missed options enabled ? Or what are the steps to get Docker runinng on TK1 ?
There is no official release of Ubuntu 16.04 for the TK1…you’d have to go to a TX1 or TX2. There are people who have 16.04 working, but they’ve given up the GPU/CUDA when doing so (the driver for the GPU is tied to the Xorg binary’s ABI in the 14.04 release…switching to the Nouveau driver implies no hardware acceleration).
