I’m looking to compile my driveworks application on in arm64 docker container that has driveworks 1.2 dependencies installed (setting up cross compilation with ros dependencies on an x86_64 arch has been a bit of a rabbit hole and so I’m abandoning that solution).
Is there a guide for implementing such a container using the new runfiles used by the sdkmanager (as opposed to driveinstall)?
I’m working with the Open Source Ros Foundation’s ubuntu_arm64 container (osrc/ubuntu_arm64 on docker hub) and attempting to install driveworks via the runfile used by the sdkmanager installer (drive-t186ref-linux-5.0.10.3-12606092-aarch64-driveworks-v1.2.400-a7f5475-478955.run)
