Hi folks,
I have tried to install dropbox on TX2 and it is not as straightforward as I thought.
Has anyone been through this process with success ?
For now, I have unsucessfully:
- tried the easy installation on ubuntu from https://www.dropbox.com/fr/install-linux
- tried to compile from sources following those directives: https://help.dropbox.com/fr-fr/installs-integrations/desktop/linux-commands
Help and shared experience appreciated,
Emmanuel
Some more information
1. APT
Once you have properly added the dropbox repo and its key, the issue is kind of straightforward: arm64 is not supported
$ sudo vi /etc/apt/sources.list
-> deb http://linux.dropbox.com/ubuntu xenial main
$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1C61A2656FB57B7E4DE0F4C1FC918B335044912E
$ sudo apt update
Error Message:
N: Skipping acquire of configured file ‘main/binary-arm64/Packages’ as repository ‘http://linux.dropbox.com/ubuntu xenial InRelease’ doesn’t support architecture ‘arm64’
2. compiling from sources
$ sudo apt install libnautilus-extension-dev python3-docutils
$ wget https://linux.dropbox.com/packages/nautilus-dropbox-2019.02.14.tar.bz2
$ tar xjf nautilus-dropbox-2019.02.14.tar.bz2
$ cd nautilus-dropbox-2019.02.14
$ ./configure
$ make
$ sudo make install
It looks good so far… but the problem comes with the next post
I am now hitting another issue, when trying to setup my dropbox…
it looks like a dead end…
$ dropbox start -i
Starting Dropbox...
Dropbox is the easiest way to share and store your files online. Want to learn more? Head to https://www.dropbox.com/
In order to use Dropbox, you must download the proprietary daemon.
Error: Platform not supported
File "/usr/bin/dropbox", line 1443, in start
download()
File "/usr/bin/dropbox", line 571, in download
for progress, status in download.copy_data():
File "/usr/bin/dropbox", line 225, in copy_data
return download_file_chunk(DOWNLOAD_LOCATION_FMT % plat(), self.local_file)
File "/usr/bin/dropbox", line 131, in plat
FatalVisibleError("Platform not supported")
File "/usr/bin/dropbox", line 536, in FatalVisibleError
sys.exit(-1)
SystemExit: -1
Eventually, I chose to install [url]https://rclone.org/[/url], which handles synchronisation with dropbox
