• Hardware Platform (Jetson / GPU) jetson xavier nx : PE1000N + I also mounted a 256GB NVMe.
• DeepStream Version : 6.2
• JetPack Version (valid for Jetson only) : 5.1.1 L4T[35.3.1]
• TensorRT Version : 8.5.2.2
• NVIDIA GPU Driver Version (valid for GPU only) x
• Issue Type( questions, new requirements, bugs) : Execution error
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) : text for code
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) : deepstream python binding, python test usb cam.
The result of running the deepstream_python_apps example.
I seem to have missed something with the Unknown black screen floating around. what action should i take?
