Hello everyone, i was hoping the community could help me with an issue I’ve encountered while trying to install ‘Folly’ as a dependency for ‘FbThrift’. Ive encountered an error that will not go away.
g++: error: unrecognized command line option ‘-msse4.2’
I have downloaded all of the dependencies according to both “Folly” and “Fbthrift” on github and nothing seems to change. I was told by the Oracle that “-msse4.2” is for intel and not recognized by the ARM instructions used by the jetson tx2.
Here is part of the log from the fbthrift deps script (which tries automatically download&install Folly) this is the script where i encounter the -msse4.2 error. The deps_ubuntu_14.04.sh also includes the necessary dependencies for 16.04 so this is not the reason for failure either.
++ cat /media/nvidia/Astro/tools/fbthrift/thrift/build/FOLLY_VERSION
+ FOLLY_VERSION=a1abbb7abcb259acbd94d0d0929b79607a8ce806
+ git checkout a1abbb7abcb259acbd94d0d0929b79607a8ce806
HEAD is now at a1abbb7... Ignore the generated file folly/libfolly.pc
+ [[ -x ./build/deps_ubuntu_14.04.sh ]]
+ autoreconf -if
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
configure.ac:39: installing 'build-aux/compile'
configure.ac:27: installing 'build-aux/missing'
Makefile.am: installing 'build-aux/depcomp'
+ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking build system type... aarch64-unknown-linux-gnu
checking host system type... aarch64-unknown-linux-gnu
checking how to print strings... printf
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert aarch64-unknown-linux-gnu file names to aarch64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert aarch64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking if g++ supports C++1y features without additional flags... yes
checking if g++ supports C++1y features with -std=c++1y... yes
checking if g++ supports C++1y features with -std=gnu++1y... yes
checking whether -Wshadow-local and -Wshadow-compatible-local are supported... no
checking for main in -lgflags... yes
checking for gflags viability... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GFLAGS... no
configure: gflags.pc not found, treating as legacy dependency
checking for main in -lglog... yes
checking for glog viability... yes
checking for GLOG... yes
checking whether compiling and linking against OpenSSL works... yes
checking for OPENSSL... yes
checking for boostlib >= 1.51.0... yes
checking whether the Boost::Context library is available... yes
checking for exit in -lboost_context... yes
checking whether the Boost::Program_Options library is available... yes
checking for exit in -lboost_program_options... yes
checking whether the Boost::Thread library is available... yes
checking for exit in -lboost_thread... yes
checking whether the Boost::Regex library is available... yes
checking for exit in -lboost_regex... yes
checking whether the Boost::System library is available... yes
checking for exit in -lboost_system... yes
checking whether the Boost::Filesystem library is available... yes
checking for exit in -lboost_filesystem... yes
checking whether the Boost::Chrono library is available... yes
checking for exit in -lboost_chrono... yes
checking for python... /usr/bin/python
checking for python version... 2.7
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.7/dist-packages
checking for python extension module directory... ${exec_prefix}/lib/python2.7/dist-packages
checking for ANSI C header files... (cached) yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking bits/functexcept.h usability... yes
checking bits/functexcept.h presence... yes
checking for bits/functexcept.h... yes
checking bits/c++config.h usability... yes
checking bits/c++config.h presence... yes
checking for bits/c++config.h... yes
checking double-conversion/double-conversion.h usability... yes
checking double-conversion/double-conversion.h presence... yes
checking for double-conversion/double-conversion.h... yes
checking for ceil in -ldouble-conversion... yes
checking for event_set in -levent... yes
checking for EVENT... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for size_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking for working volatile... yes
checking for __int128... yes
checking for __int128 type traits... yes
checking for pthread_spinlock_t... yes
checking for ifunc support... no
checking for final and override support... yes
checking for constexpr strlen... yes
checking for libc++... no
checking for c++11 atomic support without GNU Atomic library... yes
checking for liblinux-vdso support... no
checking for usable std::is_trivially_copyable... yes
checking gflags namespace... gflags
checking for weak symbol support... yes
checking for wchar support... yes
checking for unaligned access support... yes
checking for vsnprintf reporting bad format strings... no
checking for library containing cplus_demangle_v3_callback... -liberty
checking for library containing clock_gettime... none required
checking for pthread_atfork support... yes
checking for XSI style strerror_r support... no
checking for ext/random and __gnu_cxx::sfmt19937... yes
checking for VLA (variable-length array) support... yes
checking for malloc_size... no
checking for malloc_usable_size... yes
checking for memrchr... yes
checking for pipe2... yes
checking for preadv... yes
checking for pwritev... yes
checking lz4.h usability... yes
checking lz4.h presence... yes
checking for lz4.h... yes
checking for LZ4_decompress_safe in -llz4... yes
checking snappy.h usability... yes
checking snappy.h presence... yes
checking for snappy.h... yes
checking for main in -lsnappy... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for main in -lz... yes
checking lzma.h usability... yes
checking lzma.h presence... yes
checking for lzma.h... yes
checking for main in -llzma... yes
checking zstd.h usability... yes
checking zstd.h presence... yes
checking for zstd.h... yes
checking for ZSTD_compressStream in -lzstd... yes
checking linux/membarrier.h usability... yes
checking linux/membarrier.h presence... yes
checking for linux/membarrier.h... yes
checking libdwarf/dwarf.h usability... no
checking libdwarf/dwarf.h presence... no
checking for libdwarf/dwarf.h... no
checking dwarf.h usability... yes
checking dwarf.h presence... yes
checking for dwarf.h... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating libfolly.pc
config.status: creating test/Makefile
config.status: creating test/function_benchmark/Makefile
config.status: creating experimental/Makefile
config.status: creating experimental/symbolizer/Makefile
config.status: creating init/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing folly-config.h commands
config.status: creating folly-config.h - prefix FOLLY for config.h defines
config.status: folly-config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
+ make
make all-recursive
make[1]: Entering directory '/media/nvidia/Astro/tools/fbthrift/thrift/build/deps/folly/folly'
Making all in .
make[2]: Entering directory '/media/nvidia/Astro/tools/fbthrift/thrift/build/deps/folly/folly'
/bin/sh ./libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I./.. -pthread -I/usr/include -msse4.2 -std=gnu++1y -g -O2 -MT detail/libfollybasesse42_la-RangeSse42.lo -MD -MP -MF detail/.deps/libfollybasesse42_la-RangeSse42.Tpo -c -o detail/libfollybasesse42_la-RangeSse42.lo `test -f 'detail/RangeSse42.cpp' || echo './'`detail/RangeSse42.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I./.. -pthread -I/usr/include -msse4.2 -std=gnu++1y -g -O2 -MT detail/libfollybasesse42_la-RangeSse42.lo -MD -MP -MF detail/.deps/libfollybasesse42_la-RangeSse42.Tpo -c detail/RangeSse42.cpp -fPIC -DPIC -o detail/.libs/libfollybasesse42_la-RangeSse42.o
Makefile:1714: recipe for target 'detail/libfollybasesse42_la-RangeSse42.lo' failed
make[2]: *** [detail/libfollybasesse42_la-RangeSse42.lo] Error 1
make[2]: Leaving directory '/media/nvidia/Astro/tools/fbthrift/thrift/build/deps/folly/folly'
Makefile:1798: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/media/nvidia/Astro/tools/fbthrift/thrift/build/deps/folly/folly'
Makefile:1089: recipe for target 'all' failed
make: *** [all] Error 2
Failed to install Facebook Thrift
Makefile:4: recipe for target 'all' failed
make: *** [all] Error 1
This is the script with the errors when i follow the instructions provided on "folly’ README.
nvidia@tegra-ubuntu:~/folly$ mkdir _build && cd _build
nvidia@tegra-ubuntu:~/folly/_build$ cmake configure ..
-- The CXX compiler identification is GNU 6.3.0
-- The C compiler identification is GNU 6.3.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
CMake Warning at /usr/share/cmake-3.5/Modules/FindBoost.cmake:725 (message):
Imported targets not available for Boost version 106600
Call Stack (most recent call first):
/usr/share/cmake-3.5/Modules/FindBoost.cmake:763 (_Boost_COMPONENT_DEPENDENCIES)
/usr/share/cmake-3.5/Modules/FindBoost.cmake:1332 (_Boost_MISSING_DEPENDENCIES)
CMake/folly-deps.cmake:5 (find_package)
CMakeLists.txt:74 (include)
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.66.0
-- Found the following Boost libraries:
-- context
-- chrono
-- date_time
-- filesystem
-- program_options
-- regex
-- system
-- thread
-- Found DOUBLE_CONVERSION: /usr/local/lib/libdouble-conversion.so
-- Found double-conversion: /usr/local/lib/libdouble-conversion.so
-- Found LIBGFLAGS: /usr/lib/aarch64-linux-gnu/libgflags.so
-- Found LIBGLOG: /usr/lib/aarch64-linux-gnu/libglog.so
-- Found libevent: /usr/lib/aarch64-linux-gnu/libevent.so
-- Found OpenSSL: /usr/lib/aarch64-linux-gnu/libssl.so;/usr/lib/aarch64-linux-gnu/libcrypto.so (found version "1.0.2g")
-- Looking for ASN1_TIME_diff
-- Looking for ASN1_TIME_diff - found
-- Found LIBPTHREAD: /usr/lib/aarch64-linux-gnu/libpthread.so
-- Found ZLIB: /usr/local/lib/libz.so (found version "1.2.11")
-- Found BZip2: /usr/lib/aarch64-linux-gnu/libbz2.so (found version "1.0.6")
-- Looking for BZ2_bzCompressInit
-- Looking for BZ2_bzCompressInit - found
-- Looking for lzma_auto_decoder in /usr/lib/aarch64-linux-gnu/liblzma.so
-- Looking for lzma_auto_decoder in /usr/lib/aarch64-linux-gnu/liblzma.so - found
-- Looking for lzma_easy_encoder in /usr/lib/aarch64-linux-gnu/liblzma.so
-- Looking for lzma_easy_encoder in /usr/lib/aarch64-linux-gnu/liblzma.so - found
-- Looking for lzma_lzma_preset in /usr/lib/aarch64-linux-gnu/liblzma.so
-- Looking for lzma_lzma_preset in /usr/lib/aarch64-linux-gnu/liblzma.so - found
-- Found LibLZMA: /usr/include (found version "5.1.0")
-- Found LZ4: /usr/lib/aarch64-linux-gnu/liblz4.so
-- Found ZSTD: /usr/local/lib/libzstd.so
-- Found Zstd: /usr/local/lib/libzstd.so
-- Found SNAPPY: /usr/lib/aarch64-linux-gnu/libsnappy.so
-- Could NOT find LIBDWARF (missing: LIBDWARF_INCLUDE_DIR)
-- Looking for C++ include libdwarf/dwarf.h
-- Looking for C++ include libdwarf/dwarf.h - not found
-- Found LIBIBERTY: /usr/lib/aarch64-linux-gnu/libiberty.a
-- Found LIBAIO: /usr/lib/libaio.so
-- Found LIBURCU: /usr/local/lib/liburcu.so
-- Looking for C++ include malloc.h
-- Looking for C++ include malloc.h - found
-- Looking for C++ include bits/c++config.h
-- Looking for C++ include bits/c++config.h - found
-- Looking for C++ include features.h
-- Looking for C++ include features.h - found
-- Looking for C++ include linux/membarrier.h
-- Looking for C++ include linux/membarrier.h - found
-- Looking for C++ include jemalloc/jemalloc.h
-- Looking for C++ include jemalloc/jemalloc.h - found
-- Performing Test COMPILER_HAS_UNKNOWN_WARNING_OPTION
-- Performing Test COMPILER_HAS_UNKNOWN_WARNING_OPTION - Failed
-- Performing Test COMPILER_HAS_W_SHADOW_LOCAL
-- Performing Test COMPILER_HAS_W_SHADOW_LOCAL - Failed
-- Performing Test COMPILER_HAS_W_SHADOW_COMPATIBLE_LOCAL
-- Performing Test COMPILER_HAS_W_SHADOW_COMPATIBLE_LOCAL - Failed
-- Performing Test COMPILER_HAS_W_NOEXCEPT_TYPE
-- Performing Test COMPILER_HAS_W_NOEXCEPT_TYPE - Failed
-- Performing Test COMPILER_HAS_W_NULLABILITY_COMPLETENESS
-- Performing Test COMPILER_HAS_W_NULLABILITY_COMPLETENESS - Failed
-- Performing Test COMPILER_HAS_F_ALIGNED_NEW
-- Performing Test COMPILER_HAS_F_ALIGNED_NEW - Failed
-- Performing Test COMPILER_HAS_F_OPENMP
-- Performing Test COMPILER_HAS_F_OPENMP - Success
-- Looking for pthread_atfork
-- Looking for pthread_atfork - found
-- Looking for memrchr
-- Looking for memrchr - found
-- Looking for preadv
-- Looking for preadv - found
-- Looking for pwritev
-- Looking for pwritev - found
-- Looking for clock_gettime
-- Looking for clock_gettime - found
-- Looking for cplus_demangle_v3_callback
-- Looking for cplus_demangle_v3_callback - not found
-- Looking for malloc_usable_size
-- Looking for malloc_usable_size - found
-- Performing Test FOLLY_HAVE_IFUNC
-- Performing Test FOLLY_HAVE_IFUNC - Failed
-- Performing Test FOLLY_HAVE_STD__IS_TRIVIALLY_COPYABLE
-- Performing Test FOLLY_HAVE_STD__IS_TRIVIALLY_COPYABLE - Success
-- Performing Test FOLLY_HAVE_UNALIGNED_ACCESS
-- Performing Test FOLLY_HAVE_UNALIGNED_ACCESS - Success
-- Performing Test FOLLY_HAVE_VLA
-- Performing Test FOLLY_HAVE_VLA - Success
-- Performing Test FOLLY_HAVE_WEAK_SYMBOLS
-- Performing Test FOLLY_HAVE_WEAK_SYMBOLS - Success
-- Performing Test FOLLY_HAVE_LINUX_VDSO
-- Performing Test FOLLY_HAVE_LINUX_VDSO - Success
-- Looking for C++ include sys/types.h
-- Looking for C++ include sys/types.h - found
-- Looking for C++ include stdint.h
-- Looking for C++ include stdint.h - found
-- Looking for C++ include stddef.h
-- Looking for C++ include stddef.h - found
-- Check size of __int128
-- Check size of __int128 - done
-- Performing Test HAVE_INT128_TRAITS
-- Performing Test HAVE_INT128_TRAITS - Success
-- Performing Test FOLLY_HAVE_WCHAR_SUPPORT
-- Performing Test FOLLY_HAVE_WCHAR_SUPPORT - Success
-- Performing Test FOLLY_HAVE_EXTRANDOM_SFMT19937
-- Performing Test FOLLY_HAVE_EXTRANDOM_SFMT19937 - Success
-- Performing Test FOLLY_USE_LIBCPP
-- Performing Test FOLLY_USE_LIBCPP - Failed
-- Performing Test FOLLY_HAVE_XSI_STRERROR_R
-- Performing Test FOLLY_HAVE_XSI_STRERROR_R - Failed
-- Performing Test HAVE_VSNPRINTF_ERRORS
-- Performing Test HAVE_VSNPRINTF_ERRORS - Success
-- Performing Test GFLAGS_NAMESPACE_IS_GFLAGS
-- Performing Test GFLAGS_NAMESPACE_IS_GFLAGS - Success
-- Looking for C++ include elf.h
-- Looking for C++ include elf.h - found
-- Looking for backtrace
-- Looking for backtrace - found
-- Setting FOLLY_USE_SYMBOLIZER: OFF
-- Configuring done
-- Generating done
-- Build files have been written to: /home/nvidia/folly/_build
nvidia@tegra-ubuntu:~/folly/_build$ make -j $(nproc)
Scanning dependencies of target folly_base
[ 0%] Building CXX object CMakeFiles/folly_base.dir/folly/ClockGettimeWrappers.cpp.o
[ 1%] Building CXX object CMakeFiles/folly_base.dir/folly/ExceptionWrapper.cpp.o
[ 1%] Building CXX object CMakeFiles/folly_base.dir/folly/Demangle.cpp.o
[ 2%] Building CXX object CMakeFiles/folly_base.dir/folly/Conv.cpp.o
[ 3%] Building CXX object CMakeFiles/folly_base.dir/folly/Expected.cpp.o
[ 3%] Building CXX object CMakeFiles/folly_base.dir/folly/Executor.cpp.o
[ 3%] Building CXX object CMakeFiles/folly_base.dir/folly/File.cpp.o
[ 4%] Building CXX object CMakeFiles/folly_base.dir/folly/FileUtil.cpp.o
[ 4%] Building CXX object CMakeFiles/folly_base.dir/folly/Format.cpp.o
[ 5%] Building CXX object CMakeFiles/folly_base.dir/folly/FormatArg.cpp.o
[ 5%] Building CXX object CMakeFiles/folly_base.dir/folly/GroupVarint.cpp.o
[ 6%] Building CXX object CMakeFiles/folly_base.dir/folly/IPAddress.cpp.o
[ 7%] Building CXX object CMakeFiles/folly_base.dir/folly/IPAddressV6.cpp.o
[ 7%] Building CXX object CMakeFiles/folly_base.dir/folly/IPAddressV4.cpp.o
[ 7%] Building CXX object CMakeFiles/folly_base.dir/folly/MacAddress.cpp.o
[ 8%] Building CXX object CMakeFiles/folly_base.dir/folly/MicroLock.cpp.o
[ 8%] Building CXX object CMakeFiles/folly_base.dir/folly/Optional.cpp.o
[ 9%] Building CXX object CMakeFiles/folly_base.dir/folly/Poly.cpp.o
[ 9%] Building CXX object CMakeFiles/folly_base.dir/folly/Random.cpp.o
[ 10%] Building CXX object CMakeFiles/folly_base.dir/folly/ScopeGuard.cpp.o
[ 10%] Building CXX object CMakeFiles/folly_base.dir/folly/SharedMutex.cpp.o
[ 11%] Building CXX object CMakeFiles/folly_base.dir/folly/Singleton.cpp.o
[ 11%] Building CXX object CMakeFiles/folly_base.dir/folly/SocketAddress.cpp.o
[ 12%] Building CXX object CMakeFiles/folly_base.dir/folly/String.cpp.o
[ 12%] Building CXX object CMakeFiles/folly_base.dir/folly/Subprocess.cpp.o
[ 13%] Building CXX object CMakeFiles/folly_base.dir/folly/TimeoutQueue.cpp.o
[ 13%] Building CXX object CMakeFiles/folly_base.dir/folly/Try.cpp.o
[ 14%] Building CXX object CMakeFiles/folly_base.dir/folly/Unicode.cpp.o
[ 14%] Building CXX object CMakeFiles/folly_base.dir/folly/Uri.cpp.o
[ 14%] Building CXX object CMakeFiles/folly_base.dir/folly/dynamic.cpp.o
[ 15%] Building CXX object CMakeFiles/folly_base.dir/folly/json.cpp.o
[ 15%] Building CXX object CMakeFiles/folly_base.dir/folly/json_pointer.cpp.o
[ 16%] Building CXX object CMakeFiles/folly_base.dir/folly/compression/Compression.cpp.o
[ 16%] Building CXX object CMakeFiles/folly_base.dir/folly/compression/Counters.cpp.o
[ 17%] Building CXX object CMakeFiles/folly_base.dir/folly/compression/Zlib.cpp.o
[ 17%] Building CXX object CMakeFiles/folly_base.dir/folly/concurrency/CacheLocality.cpp.o
[ 18%] Building CXX object CMakeFiles/folly_base.dir/folly/container/detail/F14Table.cpp.o
In file included from /home/nvidia/folly/folly/container/detail/F14Table.h:46:0,
from /home/nvidia/folly/folly/container/detail/F14Table.cpp:17:
/home/nvidia/folly/folly/container/detail/F14IntrinsicsAvailability.h:30:5: note: #pragma message: Vector intrinsics unavailable on this platform, falling back to std::unordered_map / set
"falling back to std::unordered_map / set"
[ 18%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/AtFork.cpp.o
[ 19%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/Futex.cpp.o
[ 19%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/IPAddress.cpp.o
[ 20%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/MemoryIdler.cpp.o
[ 20%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/RangeCommon.cpp.o
[ 21%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/RangeSse42.cpp.o
[ 21%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/SocketFastOpen.cpp.o
[ 21%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/ThreadLocalDetail.cpp.o
[ 22%] Building CXX object CMakeFiles/folly_base.dir/folly/detail/StaticSingletonManager.cpp.o
[ 23%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/CPUThreadPoolExecutor.cpp.o
[ 23%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/Codel.cpp.o
[ 24%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/GlobalExecutor.cpp.o
[ 24%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/GlobalThreadPoolList.cpp.o
[ 25%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/IOThreadPoolExecutor.cpp.o
[ 25%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/InlineExecutor.cpp.o
[ 26%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/ManualExecutor.cpp.o
[ 26%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/QueuedImmediateExecutor.cpp.o
[ 27%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/SerialExecutor.cpp.o
[ 27%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/ThreadPoolExecutor.cpp.o
[ 28%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/ThreadedExecutor.cpp.o
[ 28%] Building CXX object CMakeFiles/folly_base.dir/folly/executors/TimedDrivableExecutor.cpp.o
[ 29%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/DynamicParser.cpp.o
[ 29%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/EnvUtil.cpp.o
[ 30%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/FunctionScheduler.cpp.o
[ 30%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/JSONSchema.cpp.o
[ 31%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/JemallocNodumpAllocator.cpp.o
[ 31%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/NestedCommandLineApp.cpp.o
[ 31%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/ProgramOptions.cpp.o
[ 32%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/RCUUtils.cpp.o
[ 32%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/Select64.cpp.o
[ 33%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/TestUtil.cpp.o
[ 33%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/ThreadedRepeatingFunctionRunner.cpp.o
[ 34%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/bser/Dump.cpp.o
[ 34%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/bser/Load.cpp.o
[ 35%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/hazptr/hazptr.cpp.o
[ 35%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/hazptr/memory_resource.cpp.o
[ 36%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/io/AsyncIO.cpp.o
[ 36%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/io/FsUtil.cpp.o
[ 37%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/io/HugePages.cpp.o
[ 37%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/AsyncFileWriter.cpp.o
[ 38%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/FileHandlerFactory.cpp.o
[ 38%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/FileWriterFactory.cpp.o
[ 39%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/GlogStyleFormatter.cpp.o
[ 39%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/ImmediateFileWriter.cpp.o
[ 40%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/Init.cpp.o
[ 40%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/InitWeak.cpp.o
[ 41%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogCategory.cpp.o
[ 41%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogCategoryConfig.cpp.o
[ 42%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogConfig.cpp.o
[ 42%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogConfigParser.cpp.o
[ 43%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogHandlerConfig.cpp.o
[ 43%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogLevel.cpp.o
[ 44%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogMessage.cpp.o
[ 44%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogName.cpp.o
[ 45%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogStream.cpp.o
[ 45%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LogStreamProcessor.cpp.o
[ 46%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/Logger.cpp.o
[ 46%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/LoggerDB.cpp.o
[ 47%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/RateLimiter.cpp.o
[ 47%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/StandardLogHandler.cpp.o
[ 48%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/StandardLogHandlerFactory.cpp.o
[ 48%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/StreamHandlerFactory.cpp.o
[ 48%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/printf.cpp.o
[ 49%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/logging/xlog.cpp.o
[ 49%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/observer/detail/Core.cpp.o
[ 50%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/observer/detail/ObserverManager.cpp.o
[ 50%] Building CXX object CMakeFiles/folly_base.dir/folly/experimental/settings/Settings.cpp.o
[ 51%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/Baton.cpp.o
[ 51%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/Fiber.cpp.o
[ 52%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/FiberManager.cpp.o
[ 52%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/FiberManagerMap.cpp.o
[ 53%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/GuardPageAllocator.cpp.o
[ 53%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/Semaphore.cpp.o
[ 54%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/TimeoutController.cpp.o
[ 54%] Building CXX object CMakeFiles/folly_base.dir/folly/fibers/detail/AtomicBatchDispatcher.cpp.o
[ 55%] Building CXX object CMakeFiles/folly_base.dir/folly/futures/Barrier.cpp.o
[ 55%] Building CXX object CMakeFiles/folly_base.dir/folly/futures/Future.cpp.o
[ 56%] Building CXX object CMakeFiles/folly_base.dir/folly/futures/FutureException.cpp.o
[ 56%] Building CXX object CMakeFiles/folly_base.dir/folly/futures/ThreadWheelTimekeeper.cpp.o
[ 57%] Building CXX object CMakeFiles/folly_base.dir/folly/hash/Checksum.cpp.o
[ 57%] Building CXX object CMakeFiles/folly_base.dir/folly/hash/SpookyHashV1.cpp.o
[ 58%] Building CXX object CMakeFiles/folly_base.dir/folly/hash/SpookyHashV2.cpp.o
[ 58%] Building CXX object CMakeFiles/folly_base.dir/folly/hash/detail/ChecksumDetail.cpp.o
[ 59%] Building CXX object CMakeFiles/folly_base.dir/folly/hash/detail/Crc32cDetail.cpp.o
[ 59%] Building CXX object CMakeFiles/folly_base.dir/folly/init/Init.cpp.o
[ 60%] Building CXX object CMakeFiles/folly_base.dir/folly/io/Cursor.cpp.o
[ 60%] Building CXX object CMakeFiles/folly_base.dir/folly/io/GlobalShutdownSocketSet.cpp.o
[ 61%] Building CXX object CMakeFiles/folly_base.dir/folly/io/IOBuf.cpp.o
[ 61%] Building CXX object CMakeFiles/folly_base.dir/folly/io/IOBufQueue.cpp.o
[ 62%] Building CXX object CMakeFiles/folly_base.dir/folly/io/RecordIO.cpp.o
[ 62%] Building CXX object CMakeFiles/folly_base.dir/folly/io/ShutdownSocketSet.cpp.o
[ 63%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncPipe.cpp.o
[ 63%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncSSLSocket.cpp.o
[ 64%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncServerSocket.cpp.o
[ 64%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncSignalHandler.cpp.o
[ 64%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncSocket.cpp.o
[ 65%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncSocketException.cpp.o
[ 65%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncTimeout.cpp.o
[ 66%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/AsyncUDPSocket.cpp.o
[ 66%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/EventBase.cpp.o
[ 67%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/EventBaseLocal.cpp.o
[ 67%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/EventBaseManager.cpp.o
[ 68%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/EventBaseThread.cpp.o
[ 68%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/EventHandler.cpp.o
[ 69%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/HHWheelTimer.cpp.o
[ 69%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/Request.cpp.o
[ 70%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/SSLContext.cpp.o
[ 70%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/SSLOptions.cpp.o
[ 71%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/ScopedEventBaseThread.cpp.o
[ 71%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/TimeoutManager.cpp.o
[ 72%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/VirtualEventBase.cpp.o
[ 72%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/ssl/OpenSSLUtils.cpp.o
[ 73%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/ssl/SSLErrors.cpp.o
[ 73%] Building CXX object CMakeFiles/folly_base.dir/folly/lang/Assume.cpp.o
[ 74%] Building CXX object CMakeFiles/folly_base.dir/folly/lang/ColdClass.cpp.o
[ 74%] Building CXX object CMakeFiles/folly_base.dir/folly/lang/SafeAssert.cpp.o
[ 75%] Building CXX object CMakeFiles/folly_base.dir/folly/memory/MallctlHelper.cpp.o
[ 75%] Building CXX object CMakeFiles/folly_base.dir/folly/memory/ThreadCachedArena.cpp.o
[ 76%] Building CXX object CMakeFiles/folly_base.dir/folly/memory/detail/MallocImpl.cpp.o
[ 76%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Builtins.cpp.o
[ 77%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Dirent.cpp.o
[ 77%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Fcntl.cpp.o
[ 78%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Libgen.cpp.o
[ 78%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Malloc.cpp.o
[ 79%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/OpenSSL.cpp.o
[ 79%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/PThread.cpp.o
[ 80%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Sockets.cpp.o
[ 80%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Stdio.cpp.o
[ 81%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Stdlib.cpp.o
[ 81%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/String.cpp.o
[ 81%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysFile.cpp.o
[ 82%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysMembarrier.cpp.o
[ 82%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysMman.cpp.o
[ 83%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysResource.cpp.o
[ 83%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysStat.cpp.o
[ 84%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysTime.cpp.o
[ 84%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/SysUio.cpp.o
[ 85%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Time.cpp.o
[ 85%] Building CXX object CMakeFiles/folly_base.dir/folly/portability/Unistd.cpp.o
[ 86%] Building CXX object CMakeFiles/folly_base.dir/folly/ssl/Init.cpp.o
[ 86%] Building CXX object CMakeFiles/folly_base.dir/folly/ssl/OpenSSLCertUtils.cpp.o
[ 87%] Building CXX object CMakeFiles/folly_base.dir/folly/ssl/OpenSSLHash.cpp.o
[ 87%] Building CXX object CMakeFiles/folly_base.dir/folly/ssl/detail/OpenSSLThreading.cpp.o
[ 88%] Building CXX object CMakeFiles/folly_base.dir/folly/ssl/detail/SSLSessionImpl.cpp.o
[ 88%] Building CXX object CMakeFiles/folly_base.dir/folly/stats/BucketedTimeSeries.cpp.o
[ 89%] Building CXX object CMakeFiles/folly_base.dir/folly/stats/Histogram.cpp.o
[ 89%] Building CXX object CMakeFiles/folly_base.dir/folly/stats/MultiLevelTimeSeries.cpp.o
[ 90%] Building CXX object CMakeFiles/folly_base.dir/folly/stats/TimeseriesHistogram.cpp.o
[ 90%] Building CXX object CMakeFiles/folly_base.dir/folly/synchronization/AsymmetricMemoryBarrier.cpp.o
[ 91%] Building CXX object CMakeFiles/folly_base.dir/folly/synchronization/LifoSem.cpp.o
[ 91%] Building CXX object CMakeFiles/folly_base.dir/folly/synchronization/ParkingLot.cpp.o
[ 92%] Building CXX object CMakeFiles/folly_base.dir/folly/synchronization/Rcu.cpp.o
[ 92%] Building CXX object CMakeFiles/folly_base.dir/folly/synchronization/WaitOptions.cpp.o
[ 93%] Building CXX object CMakeFiles/folly_base.dir/folly/system/MemoryMapping.cpp.o
[ 93%] Building CXX object CMakeFiles/folly_base.dir/folly/system/Shell.cpp.o
[ 94%] Building CXX object CMakeFiles/folly_base.dir/folly/system/ThreadName.cpp.o
[ 94%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/test/ScopedBoundPort.cpp.o
[ 95%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/test/SocketPair.cpp.o
[ 95%] Building CXX object CMakeFiles/folly_base.dir/folly/io/async/test/TimeUtil.cpp.o
[ 95%] Built target folly_base
Scanning dependencies of target GenerateFingerprintTables
[ 95%] Building CXX object CMakeFiles/GenerateFingerprintTables.dir/folly/build/GenerateFingerprintTables.cpp.o
[ 95%] Linking CXX executable GenerateFingerprintTables
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `bool folly::symbolizer::getStackTraceSafe<100ul>(folly::symbolizer::FrameArray<100ul>&)':
/home/nvidia/folly/folly/experimental/symbolizer/Symbolizer.h:115: undefined reference to `folly::symbolizer::getStackTraceSafe(unsigned long*, unsigned long)'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `folly::(anonymous namespace)::stackTraceGetter()':
/home/nvidia/folly/folly/Singleton.cpp:401: undefined reference to `folly::symbolizer::ElfCache::ElfCache(unsigned long)'
/home/nvidia/folly/folly/Singleton.cpp:403: undefined reference to `folly::symbolizer::Symbolizer::Symbolizer(folly::symbolizer::ElfCacheBase*, folly::symbolizer::Dwarf::LocationInfoMode, unsigned long)'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `folly::symbolizer::StringSymbolizePrinter::StringSymbolizePrinter(int)':
/home/nvidia/folly/folly/experimental/symbolizer/Symbolizer.h:320: undefined reference to `vtable for folly::symbolizer::StringSymbolizePrinter'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `void folly::symbolizer::Symbolizer::symbolize<100ul>(folly::symbolizer::FrameArray<100ul>&)':
/home/nvidia/folly/folly/experimental/symbolizer/Symbolizer.h:140: undefined reference to `folly::symbolizer::Symbolizer::symbolize(unsigned long const*, folly::symbolizer::SymbolizedFrame*, unsigned long)'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `void folly::symbolizer::SymbolizePrinter::println<100ul>(folly::symbolizer::FrameArray<100ul> const&, unsigned long)':
/home/nvidia/folly/folly/experimental/symbolizer/Symbolizer.h:214: undefined reference to `folly::symbolizer::SymbolizePrinter::println(unsigned long const*, folly::symbolizer::SymbolizedFrame const*, unsigned long)'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `folly::symbolizer::ElfCache::~ElfCache()':
/home/nvidia/folly/folly/experimental/symbolizer/ElfCache.h:118: undefined reference to `vtable for folly::symbolizer::ElfCache'
CMakeFiles/folly_base.dir/folly/Singleton.cpp.o: In function `folly::symbolizer::StringSymbolizePrinter::~StringSymbolizePrinter()':
/home/nvidia/folly/folly/experimental/symbolizer/Symbolizer.h:317: undefined reference to `vtable for folly::symbolizer::StringSymbolizePrinter'
CMakeFiles/folly_base.dir/folly/init/Init.cpp.o: In function `folly::init(int*, char***, bool)':
/home/nvidia/folly/folly/init/Init.cpp:35: undefined reference to `folly::symbolizer::installFatalSignalHandler()'
/home/nvidia/folly/folly/init/Init.cpp:54: undefined reference to `folly::symbolizer::installFatalSignalCallbacks()'
collect2: error: ld returned 1 exit status
CMakeFiles/GenerateFingerprintTables.dir/build.make:528: recipe for target 'GenerateFingerprintTables' failed
make[2]: *** [GenerateFingerprintTables] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/GenerateFingerprintTables.dir/all' failed
make[1]: *** [CMakeFiles/GenerateFingerprintTables.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
I have also tried different versions of g++ , gcc , boost, but nothing seems to be doing the trick.
